Gutting main cat *URGENT*
Old Jan 25, 2004 | 12:18 PM
ZF Six's Avatar
ZF Six
Default Gutting main cat *URGENT*
I have the cat off because I'm replacing the clutch disc and decided to gut it, I looked inside the cat and it doesn't look too easy, do I just take something metal to it and smash everything out of the middle? Is there something I need to be careful of?
Thanks,
Stephen
Old Jan 25, 2004 | 02:08 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Gutting main cat *URGENT* (ZF Six)
Just take something metal and bang all the stuff out of the cat,,, everything inside has to go........... It is a mess and you will be pounding for a while,,,, do it outside,,, and dont breath the stuff in.... you will be pleased with the results :thumbs:
IM me if you need soem help
Old Jan 25, 2004 | 02:13 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Re: Gutting main cat *URGENT* (1990CORVETTE)
:iagree:
Don't breathe it in!
Get it all out, don't want that possibly getting sucked back into the engine!
Prepare to spend some time!
Good luck!
Old Jan 25, 2004 | 02:14 PM
Flame Red's Avatar
Flame Red
:iagree:
Bash it with a iron pipe and hammer. Sort of breaks up like a hard clay pot. Put in a metal pipe inside to avoid turbulance. You can also remove all the air feed crapola if you are not in a smog **** state.
Damien89's Avatar
Damien89
Or just put a replacment straight pipe instead of the cat
Old Jan 25, 2004 | 02:25 PM
ZF Six's Avatar
ZF Six
Default Re: Gutting main cat *URGENT* (Damien89)
One word: Poor.
Old Jan 25, 2004 | 02:40 PM
1990CORVETTE
2 clamps, and a 18" pipe?
but gutting is cheaper,,,,,,
Old Jan 25, 2004 | 04:04 PM
buzzbomb's Avatar
buzzbomb
I used a spade bit on a cordless dril, tore it up quickly. :cheers:
Old Jan 25, 2004 | 09:27 PM
Brimis's Avatar
Brimis
This is just my opinion, its not a good policy to bang anything. Take a spade bit as mentioned and carefully drill out the contents of the cat. Your car will be louder, for sure.
Old Jan 25, 2004 | 10:38 PM
vetteoz's Avatar
vetteoz
Default Re: Gutting main cat *URGENT* (Brimis)
I used a long 1'' masonary drill in a rotating demolition drill.Knocked it out real fast.
To Gutting main cat *URGENT*
