Nasty rapping sound
Old Jan 25, 2004 | 04:17 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Nasty rapping sound
Nasty rapping sound coming from the passenger side valve train near the firewall. Knocking real bad and backfiring to beat the band. No smoke. Think it might be a bad lifter…any ideas?
Signed Heartbroken
:confused: :bb
Old Jan 25, 2004 | 05:20 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Nasty rapping sound (PTz-92-LT1)
Is it missing too? Pull the cover off and see what you can see before running it any more. Rapping noises are not good!
Old Jan 25, 2004 | 06:11 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Nasty rapping sound (Corvette Kid NC)
Not only is it missing, it is knocking real bad when you press the throttle down just a little under load. Don't worry, it is not and will not be driven. Will pull the valve cover off and take a look.
Old Jan 25, 2004 | 06:14 PM
Corvette Kid
If you don't see anything, run it at idle and touch the rockers one at a time. You should be able to feel which one is rapping.
Old Jan 25, 2004 | 09:28 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Nasty rapping sound is what I get when I turn the FM dial to 96 down here.
Old Jan 25, 2004 | 09:41 PM
PTz-92-LT1's Avatar
PTz-92-LT1
10-4 on the touching the rockers and the 96 FM in Miami...Will post findings.
Old Jan 25, 2004 | 09:44 PM
Corvette Kid
Default Re: Nasty rapping sound (GusBustamanteJr)
Truly, that is the WORST kind of rapping sound there is! :iagree: :lolg: :lolg: :lolg: :lolg:
Old Jan 26, 2004 | 08:35 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Going away on business for several weeks and decided to that if I can't fix the whole thing all at once, I wasn't going to get in to it part way...rust, dust, etc. Will open it up when I get back...let everyone know what I found then.
For those with positive input I thank you.
Basically this thread is dead.
Signed,
Heart Broken
:confused: :banghead: :cry :sad:
Old Jan 26, 2004 | 09:51 PM
neverendingproject's Avatar
neverendingproject
do me a favor and check for bad or burned plug wires before you tear into it. in my younger days i had a car with the same symptoms, backfired badly under acceleration. replaced the engine due to a burned plug wire. :banghead:
To Nasty rapping sound
