hooker header question
Old Jan 25, 2004 | 06:50 PM
1990CORVETTE's Avatar
1990CORVETTE
Default hooker header question
Where can I purchase these? Who sells them cheap? Are they all about $500? Is there anywhere that sells them for less? :confused:
Old Jan 25, 2004 | 06:56 PM
vader86's Avatar
vader86
Default Re: hooker header question (1990CORVETTE)
Summit Racing
Old Jan 25, 2004 | 07:00 PM
1990CORVETTE
Default Re: hooker header question (vader86)
Can I install them in my garage without a lift? :banghead:
Old Jan 25, 2004 | 07:01 PM
vader86's Avatar
vader86
if you can get it on jackstands high enough so you can move around under there, yeah
might not be the easiest or most comfortable job to do though
Old Jan 25, 2004 | 07:10 PM
johnnyevans's Avatar
johnnyevans
Advance has them (2151s) for $453 coated, just saw them in their catalog today. Make sure that you get them coated. Looked under the 89 last night, mine were painted and they look bad, not going to be fun to clean and coat now.
Old Jan 25, 2004 | 07:24 PM
1990CORVETTE
Default Re: hooker header question (johnnyevans)
Does these have the air tubes on top??????????
Old Jan 25, 2004 | 07:26 PM
HWoods's Avatar
HWoods
the 2151 do not have the air tubes the 2149's have the air tubes I installed mine in my gargae on jack stanks good luck
Old Jan 25, 2004 | 07:37 PM
LD85's Avatar
LD85
Yes, I have the car on ramps and the rear on jack stands parallel to tge ground and they will come in/out easily
Old Jan 25, 2004 | 07:39 PM
CFI-EFI's Avatar
CFI-EFI
Once again, here is the rundown on Hooker headers for 1984-1991 L83 and L98 Corvettes. Keep in mind that the basic configuration of all three part number is the same. Same flanges, same tubes, etc.
2149 >Coated. Smog hook ups for AIR pump, O2, and EGR.
2151 >Not coated. No smog hook ups. An O2 bung would have to be added or a collector with an O2 bung, used.
2151-1 >Same as 2151 except coated.
Bear in mind that the Hooker coating is to the outside, only. Many people have bought the coated Hooker headers and been happy. Others have had their Hookers coated, after purchase. (THAT sounds kind of kinky.)
You won't beat the Summit or Jegs price by much, unless you find them used. Good luck, and...
RACE ON!!!
Old Jan 25, 2004 | 08:32 PM
1990CORVETTE
Will I really see 25-30hp gain in this mod?? :eek:
Old Jan 25, 2004 | 08:49 PM
CFI-EFI's Avatar
CFI-EFI
That sounds pretty optimistic, to me. It depends on what you have done to the rest of the engine. If you haven't done or plan to do quite a bit, *I* think the 1 3/4" primary tubes are too big.
RACE ON!!!
Old Jan 25, 2004 | 09:27 PM
1990CORVETTE
Default Re: hooker header question (CFI-EFI)
OK they make the same style header, with 1 5/8 primary tubes? :cheers:
Old Jan 25, 2004 | 09:54 PM
scorp508's Avatar
scorp508
The hookers only come with 1-3/4" primary tubes. They are not too big, they work great.
Old Jan 25, 2004 | 09:59 PM
1990CORVETTE
Default Re: hooker header question (scorp508)
OK, thats solved,,,,,, beside the headers and y-pipe...... Is there anything else I am going to need to install these things
I think I will order this week
Old Jan 25, 2004 | 10:05 PM
scorp508's Avatar
scorp508
They should come with everything required. Your rear alternator bracket may not fit on again though.
Old Jan 25, 2004 | 10:13 PM
1990CORVETTE
:eek: :eek: What do I do about that
Old Jan 25, 2004 | 10:18 PM
scorp508's Avatar
scorp508
Well, some fit some don't. GM changed them so many times its hard to tell until you try. :) I run without one.
To hooker header question
Old Jan 25, 2004 | 10:21 PM
1990CORVETTE
I am sure thats what I will do,,,, calling summit tomorrow to get these things by this weekend,,,,, :yesnod: :yesnod: :yesnod: :yesnod: :seeya
Old Jan 25, 2004 | 10:39 PM
shotchkiss's Avatar
shotchkiss
Had to make a new back alt brace for my '89 when I had the headers on it, not too hard to do. They seem to fit fine for most people, not everyone has had good luck with their y-pipe however. Jegs has them for about the same price also.
Old Jan 25, 2004 | 10:41 PM
shotchkiss's Avatar
shotchkiss
Default Re: hooker header question (shotchkiss)
Oh, remember to order gaskets and decent bolts while you're at it.
