93 to 95 optispark wiring harness
Old Jan 25, 2004 | 10:45 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default 93 to 95 optispark wiring harness
i have teh 95 pigtail to go with the 95 opti but it doesn't plug into my main wiring harness, anyone done this that can point me in the right direction???
Old Jan 26, 2004 | 12:05 PM
vetteman9368
St. Jude Donor '08
Default Re: 93 to 95 optispark wiring harness (vetteman9368)
TTT, anybody? come on i know a bunch of you have done this
Old Jan 26, 2004 | 12:35 PM
DRAGRACR's Avatar
DRAGRACR
Well, you have to take your existing end off the 93 opti harness.(the one that plugs together on the passenger side intake, not the end that plugs into the opti). Just make sure that you get the wires in the same color sequence when pulling the pins out and reinstalling them in the 93 plug. If u will get a sharp pick, you can release the tab on the inside of the plug and remove the wire.
Old Jan 27, 2004 | 11:12 AM
vetteman9368
St. Jude Donor '08
Default Re: 93 to 95 optispark wiring harness (DRAGRACR)
so they go in the same order
Old Jan 27, 2004 | 02:12 PM
DRAGRACR's Avatar
DRAGRACR
Yes, just match the color of the wires that you remove and replace them with the same color wire in the new . :cheers:
Old Jan 27, 2004 | 04:52 PM
vetteman9368
St. Jude Donor '08
:thumbs:
To 93 to 95 optispark wiring harness
