Replacement stereo for a 94 corvette?
Old Jan 26, 2004 | 12:24 AM
Rottweiler's Avatar
Rottweiler
Default Replacement stereo for a 94 corvette?
Does anyone know the din size for the 94 corvette? And if you get an aftermarket radio will all the bose stuff still work good?
Thanks. :confused:
Old Jan 26, 2004 | 03:13 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Replacement stereo for a 94 corvette? (Rottweiler)
Double DIN
No, gut the rest and install decent gear.
Old Jan 26, 2004 | 10:28 AM
Fett's Avatar
Fett
As Jeffvette said it is a double din. As for the Bose stuff, rip it all out. (Including the wiring) and replace it. I did this to my '94. It takes a while, but is worth it. You will also get a SYS error message on your dash. It won't cause any problems, but gets annoying. Look around here for the fix to eliminate the SYS error. It involves putting two resistors in line to emulate the stock radio.
Old Jan 26, 2004 | 10:41 AM
bogus's Avatar
bogus
Check this out:
http://forums.corvetteforum.com/zerothread?id=470568
To Replacement stereo for a 94 corvette?
