Service ASR, Security and SYS
According to him, the security & sys lights are a separate issue from the Service ASR light. The first two signify a problem with the security system computer. The owners manual says the same thing. The ASR problem is just what it says, a problem with the traction control module.
I've already heard the security module is expensive. How about the ASR module? And are they a pain to install. I'm assuming it's difficult, since everything else on this car is.
I should add that I had the battery and alternator checked, and both were good. Also, this is not a fuel system problem. I say this because when I shut the car off and the trouble lights are on, the car will not restart. I have to wait 15 minutes. This is because since there is a security system problem, it needs 15 minutes to reset itself, then the car will restart.
