help me with burning chips
Topic says it
i want to start with burning my own chips...
have already an eprom programmer, the moates adaptor for memcal
i will work with tunercat, free Winaldl or Moates Scantools...or..Datamaster, if necessary
the car is a 90L98
Mods : Xtreme energy Cam, 258/264 206/212 @.050 In.Lobe .3200 / Ex.Lobe .3250 , 112° LSA, 1:1,52 Roller Tip Rockers, exhaust w/o cats, Single mass conversion
my first expression is, that its much better revving, also seems to have a lot more of torque at bottom and mid-range
to make the story complete, i want to burn a matching chip
idle is unstable, especially if engine gets at operating temperature...can this be a result from the closer LSA?? stock is about 117 or 114,5 if i remember correctly...
should i start from the stock BIN and work out??
ok, thats it so far...
i really hope you help me again...
thank you
You've got a lot of work ahead of you.
I would start with the stock bin file. You will PROBABLY have to change/adjust throttle stop position, TPS, commanded idle, fueling in the idle areas, and timing in the idle areas just to get the idle right.
Then, you can work on part throttle, WOT, and lots of other fun stuff.
i know, its not an easy stuff, but i think, definitely worth the effort..and i think, also necessary
if you do mods on a carbed engine, you always have to adjust the carb ...so, must be the same on a fuelie..but a bit more difficult ;)
ok, opinions are always welcome
thank you
:cheers:
eprom programmer is already at home...also a new notebook :D
the only problem is, it have only usb, rs232 is no longer available..
i built myself the akm cables Interface, which Craig has on his site
hope the notebook will "talk" with the ecm...
can i use this interface with datamaster, or something, too??
thank you
