Looking for a guesstimate on HP.
Old Jan 28, 2004 | 03:52 PM
ZZ4 GTA's Avatar
ZZ4 GTA
Cruising
Default Looking for a guesstimate on HP.
Its a 95 6spd car w/ ported LT4 heads, LT4 intake, and a comp cams 07-306-8 cam.
specs, Dur @ 0.050 lift 230/244* and lift w/ 1.6rr 0.544/0.576 on a 112 LSA.
[Modified by ZZ4 GTA, 8:52 PM 1/28/2004]
Old Jan 28, 2004 | 04:41 PM
Third Gear's Avatar
Third Gear
Default Re: Looking for a guesstimate on HP. (ZZ4 GTA)
Maybe about 450HP at the crank at 6500 RPM. It's hard to say since so many factors come into play. But I don't think you'll be disappointed. :cheers:
Old Jan 28, 2004 | 05:14 PM
ZZ4 GTA's Avatar
ZZ4 GTA
Cruising
Default Re: Looking for a guesstimate on HP. (WickedC4)
Thanks, that's what I was thinking. I've seen similar set ups put down numbers around there w/ a smaller cam. This is my first time doing a top end on a vette w/ the motor still in car. And it SUCKS!
Old Jan 28, 2004 | 05:20 PM
Zix's Avatar
Zix
Are you using longtube headers or not? Those will make big difference especailly with the ported heads and large cam. If you add the LT headers than I would say 450FWHP is attainable...without them I would say 420-425FWHP.
To Looking for a guesstimate on HP.
