Timing chain options when installing electric water pump.
Old Jan 28, 2004 | 05:43 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Timing chain options when installing electric water pump.
I'm gathering parts to replace cam, opti, water pump (with electric), etc. and would like to know what timing chains I can run when pump drive is no longer required. Does Cloyes become an option? Still learning this LT1 stuff so all help will be appreciated. Thanks.
Also, whats the recommended aftermarket gasket set for the intake I've heard about? Is OEM good for everything else?
[Modified by Corvette Kid NC, 6:39 PM 1/28/2004]
Old Jan 28, 2004 | 06:27 PM
cprgmr's Avatar
cprgmr
Default Re: Timing chain options when installing electric water pump. (Corvette Kid NC)
Yep, I'm installing a Cloyes true double roller in mine (PN# 9-3145) when I do this job in the spring... :)
Old Jan 28, 2004 | 10:25 PM
Corvette Kid
Default Re: Timing chain options when installing electric water pump. (cprgmr)
Thanks, Cloyes has always been my favorite. Part # noted. Anyone got the gasket kit brand and #?
[Modified by Corvette Kid NC, 7:38 AM 1/29/2004]
Old Jan 29, 2004 | 07:38 AM
Corvette Kid
ttt
Old Jan 29, 2004 | 07:49 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Felpro #TCS45956 , about $15. :steering:
To Timing chain options when installing electric water pump.
