Hypertech Power Coil Kit - Any noticeable improvements ?
Old Jan 29, 2004 | 05:23 PM
Meloyelo90's Avatar
Meloyelo90
Default Hypertech Power Coil Kit - Any noticeable improvements ?
Just wondering if it's really a noticeable improvement over stock...anyone have
this installed ? Thanks.
Old Jan 29, 2004 | 06:07 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Hypertech Power Coil Kit - Any noticeable improvements ? (Meloyelo90)
:lurk:
Old Jan 29, 2004 | 06:36 PM
Lone Ranger's Avatar
Lone Ranger
Unless you have low resistance aftrmarket wires it won't do much except probably cause your stock wires to fail faster. Trying to shoot higher voltage through stock carbon filled wires is like trying to suck molasses through a straw.
[Modified by Lone Ranger, 5:38 PM 1/29/2004]
Old Jan 29, 2004 | 07:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed you get the best results when you consider the "system".
I run the HyperTech coil/cap/rotor on the IROC with MSD 8.5mm wires and cut back SplitFire plugs at .0435"; and on the Vette with TPIS wires and AC Delco cut back plugs at .045".
In both cases the performance setup is worth about 8-10chp gain and a little better fuel economy.
Old Jan 29, 2004 | 08:37 PM
vader86's Avatar
vader86
No ignition system is going to give you horsepower gains unless something is terribly wrong with the current one.
Changing spark plug gaps does work though because its exposing more spark to the chamber allowing for better combustion, apparently the L98 likes more than the factory gap.
The stock cap/coil/rotor stuff is more than adequate for the L98.
Old Jan 30, 2004 | 12:01 PM
corvette Mark's Avatar
corvette Mark
I have one on my 88 and can say it is worth the money just for the cool factor of when you open the hood and see the big WARNING HIGH VOLTAGE sticker on the top. You probably won't notice a dramatic improvement but every little bit helps. :thumbs:
[Modified by lawless99, 9:02 AM 1/30/2004]
To Hypertech Power Coil Kit - Any noticeable improvements ?
