IS THE ECM BAD?
Old Jan 29, 2004 | 07:10 PM
ROCKY85's Avatar
ROCKY85
Default IS THE ECM BAD?
It's been a while had to go to work to pay the bills. Anyway the starter went out Friday and while I was replacing it I hit the knock sensor plug and the brittle plastic crumbled, well I tried to make it stay on (no luck), so out of frustration I left it disconnected and low and behold I picked up 2 miles to the gallon. The knock sensor was replaced a month ago. Up until now the best I could get on Average was 18 mpg now it's 20 mpg. I have been wondering about the ECM for long time is there a way to check it or is it best to replace it if so Autozone offers a standard one and Bosch any thoughts on what would be best.
Rocky :flag :confused:
Old Jan 29, 2004 | 07:22 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: IS THE ECM BAD? (ROCKY85)
If the ECM were not working, it couldn't have reacted to the change in the knock sensor.
Think about it.
RACE ON!!!
Old Jan 29, 2004 | 07:34 PM
SunCr's Avatar
SunCr
Absent a scanner, does the Check Engine Light work? Will it flash a Code 12 when you ground the diagnostic link? Do the MPG and Range Displays work? If these items are ok, the ECM is probably working as it should. A 2 mpg increase is negligible, but if you feel the knock sensor was retarding timing, you need a scan to verify it and even it is, that doesn't mean the sensor or the ECM is at fault. The engine could be pinging or there could be an engine noise setting it off, or the wire could be picking up interference and sending false signals to the module.
Old Jan 29, 2004 | 07:40 PM
ROCKY85's Avatar
ROCKY85
Since I don't really understand all the functions of the ECM, I thought that it may not be working properly, could the ECM be retarding spark when it should not?
Old Jan 29, 2004 | 07:44 PM
ROCKY85's Avatar
ROCKY85
Strange you should ask but the MPG and Range cleared itself and started over again 2 weeks ago and took forever to give an average (we are talking days on daily driver)
Rocky
Old Jan 29, 2004 | 08:03 PM
CFI-EFI's Avatar
CFI-EFI
Did you happen to disconnect the battery, two weeks ago?
The fact that ANYTHING changed with the disconnecting of the knock sensor, proves the ECM is sensing and reacting. The sensor can and will pick up and report "false" knock counts. The ECM will react to these by retarding the ignition to reduce/prevent, what it has been programmed to perceive as knock. Retarding the timing, hurts performance. No knock sensor, no false (or real) knock counts. No knock counts, no retarding of the timing, and improved performance and mileage. All this is no guarantee that the ECM is working perfectly, but nothing you've said raises the suspicion that it isn't. All the evidence poimts to NO ECM problems. You sound like a good candidate for a factory service manual. Good luck, and...
RACE ON!!!
Old Jan 29, 2004 | 10:09 PM
ROCKY85's Avatar
ROCKY85
No the battery wasn't disconnnected, this occured when my wife was driving the car. If you have seen my previous posts this car has undergone a major resurrection due to the poorly maintained condition it was in when we purchased it , every sensor has been replaced and all wiring has been restored to the factory condition with the exception of the cooling fan which has an adjustable thermostat to compensate for the excessive heat we have in the summer months, so it turns on sooner.
Rocky
To IS THE ECM BAD?
