IAC
Old Feb 1, 2004 | 10:39 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default IAC
Would a bad or out of tune IAC cause problems with starting the car after its fully warmed up. When its cold it turns on after the first turn. When its hot I have to give it a little gas and hold the pedal down for a sec so the car doesnt stumble. Sometimes i have to crank it for a couple of minutes to get it started. Its a 1986, 383 stroker tpi corvette.
Old Feb 1, 2004 | 11:07 PM
SunCr's Avatar
SunCr
Default Re: IAC (PMARTINEZ92126)
Offhand, no - IAC controls idle by controlling the flow of air; what you describe is typically fuel - faulty or worn injectors or incorrect injectors for application considering it's a 383.
Old Feb 1, 2004 | 11:30 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Not likely.....
Old Feb 1, 2004 | 11:49 PM
JAKE's Avatar
JAKE
I'll bet the start program in your PROM needs tweaking now that the engine is a 383.
Jake
To IAC
