My daughter is home between college semesters so I decided to take her to lunch. Jumped in the car, put my foot on the brake pedal and started the engine. All routine stuff.
The pedal was as hard as a rock. Stopping the car was as I expected with a failed power brake booster; had to about stand on the pedal.
I did all the usual checks to try to find the problem, but found nothing. I decided it must be the power brake booster, so I bought a remanufactured one from O'Reilly's Auto Parts.
When I pulled the old one off, I saw the cause. There was a crack, about 6" long, extending from the outside edge of the booster toward the center. That's why it wouldn't hold any vacuum.
Can't figure what caused this. I'd just driven the car the day before and all was well.
New booster solved the problem.
Has anyone had a similar experience or any idea of what caused this?
Hi Jake,
This seems to be a very common problem with the our Vettes.Im still running the original booster and its not a question of IF it will crack and break but WHEN.
Ive seen these kind of posts come up many times over the past.I dread the day I have to replace mine.So far,so good,and knocking on wood!
Jake,
I also think its AGE and HEAT from years of use.Just like plastic parts and vacuum lines that crack with age/heat.No getting around it too much.
I remember seeing some aluminum faced insulation material at the Ace Hardware store. Think I'll buy a small sheet and wrap the plastic booster. Maybe duct tape will hold it in place.
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Re: Cracked Power Brake Booster (Bill's86Coupe)
Jake,
Ain't that the truth. I'm always afraid to do repairs in the engine bay sometimes for the fear of bumping into a frail hose/pipe/connection/etc. and breaking them. Yikes. :lol:
