Gauge cluster removal...
Old Feb 3, 2004 | 12:05 AM
SmokyMcGee's Avatar
SmokyMcGee
Default Gauge cluster removal...
I got the 4 bolts out of the cluster but was unable to get it out of the dash. I can't see too well in there but it looks as if the wiring harness is holding it in on the right side. How does one go about removing this without having the harness shrink back to where I will have great difficulty hooking it back up again?
Old Feb 3, 2004 | 01:56 AM
D_C71's Avatar
D_C71
Default Re: Gauge cluster removal... (SmokyMcGee)
There are Safety Retaining Clips at the Harness connectors that need to come off first. Just get the Cluster Out and you can work on increasing the Slack in the Harness for re-installation with more working room (cluster out.)
Old Feb 3, 2004 | 08:33 AM
cprgmr's Avatar
cprgmr
There's a write up in the Tech Tips section of the forum for instrument cluster removal - check it out! :) :cheers:
Old Feb 3, 2004 | 09:48 AM
rick lambert's Avatar
rick lambert
Default Re: Gauge cluster removal... (cprgmr)
I know that feeling-I'm waiting for warm weather first. But go to http://www.corvettedashclusterservic...0Process1.html
Everyone I've spoke with had no problem-but it does look :eek: re-installation looks like it might be the most difficult part-but nobody has commented on it. :seeya
Old Feb 3, 2004 | 01:40 PM
dwestsr's Avatar
dwestsr
Default Re: Gauge cluster removal... (rick lambert)
Once you get those safety clips off , it should be easy to remove the two harness plugs. You will need to turn the cluster just right to get it out, but it will come. I found that I had to put a little upward pressure on the dash pad (not too much) to get the clearance I needed. Reinstall is easier that removal. I know cause I did it numerous times before I finally got the darn thing fixed. :cheers:
Old Feb 3, 2004 | 03:32 PM
D_C71's Avatar
D_C71
Default Re: Gauge cluster removal... (dwestsr)
:iagree:
Old Feb 3, 2004 | 05:39 PM
SmokyMcGee's Avatar
SmokyMcGee
thanks guys. Im gonna try at it again.
Old Feb 4, 2004 | 09:22 AM
rick lambert
Hey Smoky,
let us know how it went :rolleyes: any little tricks are always nice to know. :seeya
Old Feb 4, 2004 | 05:32 PM
SmokyMcGee's Avatar
SmokyMcGee
Got the cluster out..found the two blown bulbs... paid about $33 for two bulbs. Not happy with that price at all. :nono:
Old Feb 4, 2004 | 06:27 PM
Wamuscat87's Avatar
Wamuscat87
I need to take mine out any good websites besides the one above.
Old Feb 4, 2004 | 06:42 PM
SmokyMcGee's Avatar
SmokyMcGee
Default Re: Gauge cluster removal... (Wamuscat87)
It was pretty straight forward. It was kind of tough to wedge it out but with some twisting and turning it comes out. I snapped a harness safety clip taking those off so be careful with those.
To Gauge cluster removal...
