part name?
Old Feb 4, 2004 | 05:45 PM
quiksilver458's Avatar
quiksilver458
Default part name?
Can anyone tell me what the round disc/ plate looking thing is called that is bolted straight to the waterpump on l98's? I wanted to try and search the archived threads. Anyway, Buddies vette has some weird vibration/rattling sound coming from that area.. I remember reading a post sometime ago about how this piece is often removed because it serves no real purpose.. any info would be appreciated! :cheers:
[Modified by quiksilver458, 6:25 PM 2/4/2004]
Old Feb 4, 2004 | 07:01 PM
BAM92's Avatar
BAM92
Default Re: part name? (quiksilver458)
I think it is known as the "frisbee". And most people remove it to gain less drag on the motor, freeing up a little hp.
Old Feb 4, 2004 | 07:12 PM
autotech's Avatar
autotech
Default Re: part name? (BAM92)
What does it do? It's ok to take it off???
Old Feb 4, 2004 | 07:39 PM
1MoorTym's Avatar
1MoorTym
Its called a damper - I'd leave it on.
Old Feb 4, 2004 | 07:56 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: part name? (1MoorTym)
:cheers: It is OK to remove it! GM thought they might have a problem with AC clutch so they bought thousands of the Frisbees to smooth out the clutch action...but they proved unnecessary!
To hide from the "bean counters" they installed them anyway, since they bought 'em! :rolleyes:
When you remove, add a few washers equal to the thickness of the Frisbee to keep the pulley lined up.
You will feel a difference, particularly when accelerating from 70+
:seeya
:steering:
[Modified by jackdaroofer, 7:58 PM 2/4/2004]
Old Feb 4, 2004 | 10:01 PM
Klatu91's Avatar
Klatu91
Default Re: part name? (jackdaroofer)
When you say, "You will feel a difference when accelerating from 70+", is that a good difference as in increased hp or is it a bad difference as in vibration? :auto:
Old Feb 4, 2004 | 10:05 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: part name? (Klatu91)
I took mine off. No vibrations here w/ or w/o the a/c on or when the a/c clutch engages.
It seems to have more pickup. Either way, the 5 or 6 lbs on the waterpump shaft can't be good for its bearings.
Chris
To part name?
