MAF screen
Old Feb 6, 2004 | 12:35 AM
Rottweiler's Avatar
Rottweiler
Default MAF screen
Is it ok and is it beneficial to remove the screen from you're MAF sensor and does it bother anything if you do? Thanks
Old Feb 6, 2004 | 12:45 AM
Curveit's Avatar
Curveit
Default Re: MAF screen (Rottweiler)
I'm not sure if It really helps or not; I'm sure someone will jump in here, but I read about it first in TPIS catalog and they claim It does. Cut out my screens and vanes 2 yrs ago, with no problems.
:chevy
Old Feb 6, 2004 | 12:57 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
How about 4 RWHP? See the thread below...
http://forums.corvetteforum.com/zerothread?id=646170
:cheers: -JRC-
Old Feb 6, 2004 | 02:15 AM
dtorc4's Avatar
dtorc4
The purpose of the screens is to straighten the turbulent airflow coming from the airfilter. It does reduce CFM, but if your engine needs the extra airflow, then it would be beneficial to remove the screens.
The vains are a heat sink for the electronics inside the MAF sensor. Again, if your engine needs the additional airlfow, your should cut them down.
Old Feb 6, 2004 | 01:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: MAF screen (dtorc4)
:iagree:
If you remove the screens also cover the sensor tube ends and cut off the heat sink fins to get the max. air flow potential.
If you run a L98 MAF without screens:
-never run the engine (except for diagnostics) without an air filter
-do NOT over oil your K&N air filter
Old Feb 6, 2004 | 01:45 PM
Lone Ranger's Avatar
Lone Ranger
L98: remove it
LT1/LT4: Leave it in.
:lurk:
<edit> removing it on an LT1 or LT4 only serves to throw the MAF/ECM slightly out of calibration/sync... on a stock engine anyhow.
[Modified by Lone Ranger, 12:49 PM 2/6/2004]
Old Feb 6, 2004 | 02:20 PM
vader86's Avatar
vader86
Since you have a 94, leave it in. It only helps L98s.
And dont buy any Granatelli MAF or anything like that either until you do some real mods.
To MAF screen
