Hi guys,
I'm going through an emissions dilemna.
I've found that a failed injector has ruined my cats.
I need opinions on 2 things:
1. Where's a good (cheap price :yesnod: ) online place to buy cats?
2. What happens if I decide to leave the pre-cats alone (I also assume they are bad) and replace the rear one with a higher rated capability i.e "good for engines up to 455 c.i.d"
I'm pretty certain because of the horrendous smell- like having no cats at all. I changed out the O2 sensor and the smell is the same. I'm going to work on the injectors soon and can only hope for a miracle, but I doubt it!
I have no clue. I've only had the car since oct. and it has been spitting out gunk out of the exhaust the whole time. I noticed the injectors were bad when one sprung a leak and i limped home, then noticed another was only pulling 12ish in the ohm range. I did notice that sometimes my car's exhaust sounded better than others...like i was breathing better at times.
