new rebuilt alternator problem
Old Feb 8, 2004 | 12:48 PM
dwestsr's Avatar
dwestsr
Default new rebuilt alternator problem
I just installed a rebuilt alternator (CS 130 from a 93) in my 86 coupe . Reason for the change was bad bearings in the old one. The new one charges fine at lower RPM but voltage drops below 12 at ~ 3000 RPM. Does anyone know what causes this , Is it a bad voltage regulator? Thanks for your help on this. I'm stumped. :cheers:
[Modified by dwestsr, 2:09 AM 2/9/2004]
Old Feb 8, 2004 | 09:08 PM
dwestsr's Avatar
dwestsr
Default Re: new rebuilt alternator problem (dwestsr) Update
Hey folks , this is a rally strange one. I drove the car ~4 hours today and the alt was putting out 14.2 volts as long as I drove normally. Whenever I got on it the Voltmeter dropped to battery volts. Came back to normal when I resumed cruise speed. I just finished a rebuild on my spare alt. just in case, cause I don't trust this one. Should I try to figure this out or just get it replaced under warranty? Need some help!!! :cheers:
Old Feb 8, 2004 | 11:01 PM
jfb's Avatar
jfb
You have a defective alternator, take it back. That alternator has out of round slip rings which at high rpm lift the brushes and turn off the field current shutting off the alternator.
Old Feb 9, 2004 | 03:09 PM
dwestsr's Avatar
dwestsr
Default Re: new rebuilt alternator problem (jfb)
Thanks , You are right. I'm gonna take that one back. :cheers: :cheers: :cheers:
To new rebuilt alternator problem
