Need to reset the DIC - LPTWS ?
Old Feb 8, 2004 | 07:48 PM
froggy47's Avatar
froggy47
Default Need to reset the DIC - LPTWS ?
I replaced my LF sensor - the band broke when the tire was rotated. The LPTWS light is now out. Do I need to reset anything? The "Tire low" never came on just Service LPTWS - no signal detected.
Anyone need a LF sensor - you'll have to get a band from Corvette Salvage or wherever? The tire store - Costco - had to buy the band/sensor as a unit so I've got a spare.
Old Feb 9, 2004 | 01:12 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Need to reset the DIC - LPTWS ? (froggy47)
To clear codes you have to ground pins #6 to #5, 3 times within 10 seconds with the ignition "on". The receiver will confirm codes have been cleared by turning on both Low/flat tire & Servive LPTWS lamps at the same time. They will stay on until the ignition is turned "off".
