AFR problems
Old Feb 9, 2004 | 04:27 AM
ben73's Avatar
ben73
Default AFR problems
Hello,
A month or so ago there was a post where someone had a problem with his AFR's where the decks were badly pitted after machining.
With the search function being broken,I cannot find this thread.
Does anyone remember what the title was?
Thanx.
Old Feb 9, 2004 | 04:43 AM
86PACER's Avatar
86PACER
Default Re: AFR problems (ben73)
The search function is working. There are numerous threads about problems with AFR. I do not know the title of the specific one you are looking for.
If you do a search using the title "AFR" you should get all the threads that are related to AFR. Then you can go from there. :auto:
Old Feb 9, 2004 | 08:23 AM
RonRed89's Avatar
RonRed89
You need to search for posts by user "ld85". He was the one who had the issue with the pitting that you described.
Ron
To AFR problems
