Service Ride Control
Old Feb 9, 2004 | 08:42 AM
Calif Vetteman's Avatar
Calif Vetteman
Default Service Ride Control
My service ride control light came on this morning, and stayed on. The last time this happened is when the battery went dead. I have 28200 miles on a 93 6speed. I hate giving my car to a dealer for any repairs. Any thoughts on the cause of the warning light. What service can be done to the ride control. It is the FX3. Thanks :seeya
Old Feb 9, 2004 | 11:41 AM
Flame Red's Avatar
Flame Red
Default Re: Service Ride Control (Calif Vetteman)
One common thing about the service ride control. If you turn you ignition on and off three times in a row without moving the car the SRC will light. Make sure this is not why yours is on.
Old Feb 9, 2004 | 11:44 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Do it yourself. You will die when you hear the dealer quates on prices.
Pull the codes and start from there. Not sure if it's the same way for a 93 car. Hopefully somebody will know for sure. But get the codes and come back and let us know.
Old Feb 9, 2004 | 03:25 PM
Yellow95's Avatar
Yellow95
I have a '95 with 93,000 miles. My light came on for the second time last week. If you are any good with a wrench you can save yourself a ton of beer money. I believe the method for pulling the codes is different on your car than it is on mine. On mine, the star gear on the top of the shock broke, once in the front, once in the back. I was able to epoxy them back together for a free fix. Soon I will need a new actuator on the back. The cost of the parts on these systems is horrible. :smash:
Old Feb 10, 2004 | 08:24 AM
Calif Vetteman
Default Re: Service Ride Control (Yellow95)
:crazy: Thanks. The code read 32, which is an actuator. I have to find out which shock is giving out the code. :seeya
Don't forget to WAVE
Old Feb 10, 2004 | 10:20 AM
Jeffvette's Avatar
Jeffvette
32 = Right Front out of position
Out of position codes are triggered if the computer senses that the actuator has not found the end stop position on the shock. Remove actuator at the indicated shock. Turn the valve gear on the shock stops after about 3 / 4 of turn, then you have a bad actuator. If it spins around continuously then it is a bad shock
Old Feb 10, 2004 | 10:23 AM
c4cruiser's Avatar
c4cruiser
Default Re: Service Ride Control (Jeffvette)
If the shock turns out to be bad, Bilstein can rebuild them and if you want, even change the damping rate. Call Bilstein at 1-800-537-1085 and talk to them. That number is in San Diego, CA.
Old Feb 10, 2004 | 03:06 PM
Calif Vetteman
Default Re: Service Ride Control (c4cruiser)
Thanks for the info. :seeya
Old Feb 10, 2004 | 05:01 PM
lbitp37's Avatar
lbitp37
When mine stayed on I took it to a very good Vette only shop, I paid $56.00 for the computer check.
Needed a new right front actuater. He repaired it for another $165.00. :rolleyes:
Old Feb 10, 2004 | 08:09 PM
1990CORVETTE's Avatar
1990CORVETTE
[QUOTE]32 = Right Front out of position
Isnt that the EGR code
Old Feb 10, 2004 | 08:11 PM
1990CORVETTE
Mine also came on for about 10 minutes the other day and hasnt came back on sice,,,,, hell no telling :confused:
Old Feb 10, 2004 | 08:25 PM
Jeffvette's Avatar
Jeffvette
Default Re: Service Ride Control (1990CORVETTE)
Different system.
Old Feb 11, 2004 | 08:33 AM
Calif Vetteman
:hurray: Good news! It was the clip on top of the shock that had slipped down. I guess I had dislodged it durning cleaning. Thank God I have an honest mechanic. I did have the back up lights switch, that is on top of the tranny replaced. Thanks for everyones help. :thumbs: :seeya
To Service Ride Control
