Help - Need pics / advice for L98 emissions hoses (post intake man install)
OK, I spent the whole weekend getting the manifold, runners, plenum, etc...
back in my 90 L98, but now I have some extra vacuum hoses ? on the drivers
side and cannot figure out how they attach or where they connect. I'm pretty sure one of them goes the the rear passenger side of the plenum, but I broke these (14 yrs old) when I took them off and don't remember the original routing.
Does anyone have drivers side pics of the 90 L98, or know where I can find any ?
Yes, I learn the hard way - next time it's pics pics pics.
Thanks.
Thanks.
Re: Help - Need pics / advice for L98 emissions hoses (Meloyelo90)
Sorry - this wasn't meant to be a poll, it's a new topic. I'm still sleepy
from working on the car all weekend... :banghead:
Look at my pics,, it you need a closer one let me know and I can go snap a shot for you :cheers:
Send me a pic of the area you want and I will see what I can do for you tonight. :seeya
Re: Help - Need pics / advice for L98 emissions hoses (1990CORVETTE)
Thanks guys - I can kind of see on a pic from 1990CORVETTE. What I need
in particular (if you have one laying around) is drivers side between the TB
and the first two injectors. In the pic I saw, there seems to be something mounted
on the thermo housing, which could be what I have extra. Also, if you have it,
a pic of the passenger side by the fuel regulator. There are two connections from the plenum, then one underneath that I can't figure out (EGR ?). My photographic memory has turned into mush. Thanks very much.
1 Post
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
The one on driver front thremo housing is the egr silinoid has has 3 connections (SP?). It connects to the silinoid than egr other side of silinoind third connection under throttle body originate from a line on the drivers side wheel well,The two passinger rear intake one is for fuel regulator and the other connects to a valve running along the firewall it is a black barrel sitting around dist.
