Timing Set question
Old Feb 9, 2004 | 03:37 PM
nonetooclose's Avatar
nonetooclose
Default Timing Set question
Does anyone know whether or not the 1985 Vette had the covers over the timing set that the chain rode on? This is what caused many problems with running quality on the trucks I saw a while back. Just trying to figure out if I will be able to refresh my engine instead of replacing it.
Richard
Old Feb 9, 2004 | 03:41 PM
scorp508's Avatar
scorp508
Default Re: Timing Set question (nonetooclose)
I don't quite follow you. The timing cover has no itneraction with the chain and sprockets as far as I know. There may be a nose on the cam or something as it isn't a rollercam, but I am not sure.
Old Feb 9, 2004 | 04:32 PM
JAKE's Avatar
JAKE
I don't understand the question either.
Jake
Old Feb 9, 2004 | 06:25 PM
CFI-EFI's Avatar
CFI-EFI
I agree, that the way it is worded, it makes no sense. Maybe he is talking about the nylon coating on the teeth of the cam sprocket? But no matter what, it wouldn't be a factor in whether the engine could be be rebuilt or have to be replaced. Unless there is a coherent clarification, I would have to recommend you take the car to someone and have, whatever, done for you. GOOD luck, and...
RACE ON!!!
Old Feb 9, 2004 | 08:04 PM
EDMGUY's Avatar
EDMGUY
Default Re: Timing Set question (CFI-EFI)
RACE ON!!!
:iagree:
Old Feb 10, 2004 | 01:40 AM
nonetooclose
Default Re: Timing Set question (EDMGUY)
Okay okay. I am referring to the nylon coating encasing the outer teeth of both the crank and camshaft sprokcket on these earlier 350s. I have a 77 which had this particular piece and was the sole cause for rough running conditions later in the engine's life.
It actually has a lot of bearing to whether or not I rebuild or replace. I have in mind not a rebuild, but a refresh where I would replace the worn timing set, distributer, and possibly redo the heads. This way I do not have to remove the engine from the car which is very difficult for me to accomplish with space limitations.
I am not sure if the same nylon covering is on the 85's or not.
Richard
[Modified by nonetooclose, 6:41 AM 2/10/2004]
Old Feb 10, 2004 | 02:04 AM
scorp508's Avatar
scorp508
Ok now that we're all on the same boat. :) That is a very good question and I don't know if we can answer it. Some say all early C4s had it, but when I pulled my '87 apart for the first time ever there was no nylon on the gears and the chain wasn't sloppy. :crazy:
Old Feb 10, 2004 | 04:20 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My 85 Corvette (produced in Apr 84) had the factory cam gear with nylon teeth. The gear itself is actually cast aluminum I think, and it has small aluminum teeth, which have a thick nylon coating on em... which builds em up to the normal tooth size. The factory crank gear is steel.
I replaced em with an all steel timing set from Napa. I've seen pics of a guy on here who's nylon cam gear teeth sheared/melted off.
I have my original timing set sitting on my desk (as a decoration!).. and dropped it once by accident, and it actually broke three of the nylon teeth! :rolleyes: Now that's pathetic.
Old Feb 10, 2004 | 10:37 AM
scorp508's Avatar
scorp508
Default Re: Timing Set question (CentralCoaster)
:eek: :eek: Thats horrible!!! My sprockets were nothing like the ones you describe. It'd be interesting to hear when and why they did and didn't use them.
Old Feb 10, 2004 | 11:28 AM
Curveit's Avatar
Curveit
I don't know what years they used them, but I know they used them because they are quieter than bare metal. Not as strong though; I'd use metal.
:chevy
Old Feb 10, 2004 | 12:36 PM
CFI-EFI's Avatar
CFI-EFI
That clarifies the origional post, but it still leaves questions. First, I have never seen a nylon coated crank sprocket. And unless sections of nylon were missing from the cam sprocket, it wouldn't cause rough running.
Distributor??? You would make a decision as to whether you would "refresh" or replace, based on the type of timing set origionally installed? The condition of the bores, rings, or bearings wouldn't be a factor?
The engine is easier to remove for replacement, than for overhaul? I don't get it. What am I missing here? I have to reiterate my initial statement. I think you should take this car somewhere, for whatever it ends up needing. GOOD luck, and...
RACE ON!!!
Old Feb 10, 2004 | 03:06 PM
CentralCoaster
I think what he's indicating, is that if a sloppy timing chain is mostly whats causing the car to run poorly, than a new timing chain will help. Otherwise he's going to dig deeper and maybe start rebuilding.
Old Feb 10, 2004 | 03:58 PM
nonetooclose
It is quite simple really. Chevy in their utmost scrupulous fashion put plastic coated timing sets in the ealier engines just like what was indicated prior to "make them quieter". This is quite ridiculous since I have never even heard a timing set make any noise unless it is a geardrive. As the car ages the plastic gets old and brittle due to chemicals and acids in the oil created during combustion and engine use. This in turn breaks down the plastic and as a couple of people have indicated the gear literally dissolves. This dissolution actually creates a terribly running vehicle since it is gradual as the gear looses integrity.
I reiterate, just as Centralcoaster pointed out, that it is a refresh not a rebuild. Careful of the definitions here. A refresh is just that, a refresh of easily accessible parts without tearing the whole engine down for a complete rebuild.
This is preventative maintanence since I know that these sets are a problem. Is there a confirmation that the 1985's do have these nylon cam gears?
Richard
Old Feb 10, 2004 | 07:06 PM
CFI-EFI's Avatar
CFI-EFI
I don't think there is a lot of argument about the desirability of the nylon coated cam sprocket. I cannot state positively, but I am relatively sure that the '85 does have the coated sprocket. I just want to see if I have understood you correctly. If the engine has an all metal cam sprocket, you are going to change the timing set, the distributor, and possibly have a valve job done. Assuming for the moment, the sprocket IS all metal, what criteria will you use to determine if you do the valve job? If the engine does have a nylon coated cam sprocket, you will replace, not rebuild, but replace the engine. Do I read you correctly?
Old Feb 11, 2004 | 11:07 PM
nonetooclose
Close! The reason this is coming up, is that I am going to be performing some PM (preventative maintanence) on my vette and replace my 120K water pump which happens to need to have most of the stuff in the way of the timing set removed. Since I am down there and if the timing set is nylon, they go at approx 100K miles as well as the water pump. I am hoping to replace these two parts. I am also thinking about instead of actually refinishing the head, swapping them out along with the intake manifold for a set of vortec heads (SDPC vortec baseplate). I am also thinking about at least inspecting the distributer cam gear, but probably will forgoe this.
The criteria for the valve job would be an inspection of the valve seats looking for wear on the seats and the valve itself. I suspect they are fine, so my most probable scenario is to simply replace the timing set and water pump. Thanks for all the input!
Thanks for the pic Centralcoaster. That is exactly what I am afraid of! It seems pretty conclusive that the 85 does have this nylon coated cam gear. Any recommendations for a good timing set?
Richard
Old Feb 12, 2004 | 01:38 PM
CFI-EFI's Avatar
CFI-EFI
Since it appears that the cam sprocket IS nylon coated, that means a replacement engine.
The replacement engine will come with a timing set. Rendering THIS question, moot. IF you are looking for an economical replacement timing set, medium duty trucks come with a factory double roller set up.
Old Feb 12, 2004 | 01:53 PM
scorp508's Avatar
scorp508
I run a Cloyes True Double Roller timing set which is ~$85 if I remember correctly.
To Timing Set question
