Changing 700r4 shift points....
Old Feb 9, 2004 | 08:20 PM
Wheelman's Avatar
Wheelman
Default Changing 700r4 shift points....
I see some of you have done mods to change your shift points on your 700r4, and i was wondering what are the optimum shift points, and how you change them.
Thanks in Advance
Old Feb 9, 2004 | 08:30 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Changing 700r4 shift points.... (Wheelman)
:cheers: I have modified mine by playing around with the TV cable adjustment. Can't give you any well defined prameters, hjust kind of hit and miss. Doesn't even try to shift into OD/lock up till I let off the gas at over 55 mph. Wish I could be more specific :bb
:seeya
:steering:
Old Feb 9, 2004 | 08:33 PM
86Moon's Avatar
86Moon
http://forums.corvetteforum.com/zerothread?id=686231 :jester
Old Feb 9, 2004 | 08:34 PM
CFI-EFI's Avatar
CFI-EFI
The optimum shift points depend on your engine. And gearing to a degree. Every car is different. You will have to experiment to find yours. To change the shift points, you have to recalibrate the governer. Several companies sell a recal kit, with a varity of weights and springs. It's kind of like recurving an old centrifugal advance distributor.
RACE ON!!!
Old Feb 10, 2004 | 01:10 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Re: Changing 700r4 shift points.... (86Moon)
Yep, I remember that post. Since then the tranny was completely gone thru and a few extras added. First a B&M shift kit. A twelve vane oil pump, and a 4th gear servo kit. My tranny guy also setup the governor cover with a bail clip like the turbo 350-400. This way I can open the governor for fly-weight changes without too much hassle... I'll have more to report once everything is back together...
:cheers: -JRC-
Old Feb 10, 2004 | 01:50 AM
65Z01's Avatar
65Z01
As stated the optimum WOT shift points depend on the engine torque curve.
You need to shift past the power peak but not too far beyond. Remember power drops off after the peak but is cut in half after the 1-2 shift point.
To determine the best WOT shift points you can use time slips at the drag strip or Drag2000 software simulation.
Old Feb 10, 2004 | 03:58 AM
korvette4u's Avatar
korvette4u
Thanks in Advance
check out this link: http://www.tvmadeez.com/tvcable_inst...tockcable.html it should explain general set up....or this link for TV cable adjustment 101 http://www.tvmadeez.com/article/index.html :thumbs:
To Changing 700r4 shift points....
