Compression/blowby question
Old Feb 10, 2004 | 01:42 AM
THEVETTEINMYGARAGE's Avatar
THEVETTEINMYGARAGE
Cruising
Default Compression/blowby question
Im installing the GM hot cam kit on my 95 LT1. Had the heads redone and am in the process of putting it all back together. Oil pans off drivers side head is back on without rockers. Installed new time chain and gears and while rotating to TDC I can hear air escaping from the, I assume bottom of the cylinders as the crank rotates aroud. Car has 60K on it cylinder walls look fine there was some carbon build up on the tops of them. New rings?
Old Feb 10, 2004 | 02:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Compression/blowby question (THEVETTEINMYGARAGE)
Well there is always some blow by, even with a complete rebuild.
Did you run a compression check before breakdown? Was it burning oil before the breakdwon?
Old Feb 10, 2004 | 04:53 AM
JAKE's Avatar
JAKE
[SNIP]Oil pans off drivers side head is back on without rockers. [/SNIP]
I don't quite understand this line.
Jake
Old Feb 10, 2004 | 06:44 AM
Tom Piper's Avatar
Tom Piper
If you have concerns, the best thing to do is a leak-down test of the cylinders.
The percentage of leakage will tell you if there are any problems. After break-in, anything above about 10% is considered too high for a racing engine, but I think 15% is considered the line for a street car.
Since the rings are not perfect seals, my guess is what you are hearing is normal.
Tom Piper
Old Feb 10, 2004 | 07:14 AM
rick lambert's Avatar
rick lambert
Default Re: Compression/blowby question (Tom Piper)
I've heard that b4, normal, with 60k I wouldn't worry about it, the carbon buildup is also normal. :auto:
Old Feb 10, 2004 | 01:58 PM
THEVETTEINMYGARAGE
Cruising
Default Re: Compression/blowby question (65Z01)
It wasnt burning oil brfore I torn it down and I didnt do a compression test. I thought after hearing the air escaping I might need new rings
Old Feb 10, 2004 | 02:02 PM
THEVETTEINMYGARAGE
Cruising
Default Re: Compression/blowby question (JAKE)
Thanks you all for you help.
To Compression/blowby question
