3/8...7/16....HEAD BOLT ?????
Old Feb 10, 2004 | 07:44 AM
redcorvettedave's Avatar
redcorvettedave
Default 3/8...7/16....HEAD BOLT ?????
I have a LT1 motor.....with 3/8 Roller rocker studs...My question can I use 7/16 studs or not a good ideal.....will they come loose or shoulld i stick to 3/8 :conehead I'm up grading to 1.6 or 1.7 RRs
[Modified by redcorvettedave, 12:45 PM 2/10/2004]
Old Feb 10, 2004 | 07:57 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: 3/8...7/16....HEAD BOLT ????? (redcorvettedave)
I understood that you had to get the threads in your heads modified to take the 7/16" studs. The main benefit being that they are a stronger setup.
Old Feb 10, 2004 | 10:59 AM
Curveit's Avatar
Curveit
You don't have to rethread; they will fit, and are stronger. If you are going to get new rockers anyway, I would use 7/16. Check to get proper ones, depending on useing guide-plates or not. I you use self-aligning rockers, don't use guide-plates. If you use standard rockers (not self-aligning), use guide-plates, and hardened pushrods.
:chevy
Old Feb 10, 2004 | 11:13 AM
scorp508's Avatar
scorp508
Default Re: 3/8...7/16....HEAD BOLT ????? (Red 90 L98 Coupe)
The old iron heads had press-in 3/8" studs. The aluminum heads have threads for a 3/8" shank, but that is the same size shank on the 7/16" studs. The part that screws into the head is smaller than the actual rocker stud above it.
Old Feb 10, 2004 | 03:25 PM
JAKE's Avatar
JAKE
Default Re: 3/8...7/16....HEAD BOLT ????? (scorp508)
Huh?
Jake
Old Feb 10, 2004 | 03:27 PM
scorp508's Avatar
scorp508
Default Re: 3/8...7/16....HEAD BOLT ????? (JAKE)
Huh?
Ok. The lower part of the rocker stud part that screws into the cylinder head is 3/8" no matter if it is a 3/8" stud or 7/16" stud on the top side for the rocker. :)
Old Feb 10, 2004 | 03:46 PM
Curveit's Avatar
Curveit
:iagree: Yep! :chevy
Old Feb 10, 2004 | 11:18 PM
JAKE's Avatar
JAKE
Huh?
I think you need to check that.
Every SB head I've come across that has screw in studs has 7/16 x 14 threads on the end that screws into the head. In fact, Big Block studs, which are 7/16th on both ends (7/16th X 24 top and 7/16th x 14 bottom), screw right in to the SB head and are a direct replacement/upgrade.
The only Chevy studs that I know of that are 3/8th (in the head) are for the Mark V and VI big block engines.
Jake
Old Feb 10, 2004 | 11:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
:iagree:
The base of my stock rocker studs was 7/16" but the top was 3/8"; my 7/16" rocker studs are 7/16" top & bottom.
When going to 1.6:1 RRs upgrading to 7/16" studs is a good idea to assure valve train stability; with 1.7:1 RRs it is an even better idea. When the studs deflect under load you lose valve lift.
Old Feb 10, 2004 | 11:48 PM
scorp508's Avatar
scorp508
Honest mistake, same principal idea. No modifications needed.
Old Feb 10, 2004 | 11:56 PM
Curveit's Avatar
Curveit
:iagree: Yep. Brain fade here. :chevy
To 3/8...7/16....HEAD BOLT ?????
