Coated Headers & Underhood Temps
Feb 10, 2004 | 09:53 AM
Do underhood temps increase or decrease when going to coated headers form stock exhaust manifolds?
Feb 10, 2004 | 09:58 AM
St. Jude '03-'04-'05-'06-'07
Re: Coated Headers & Underhood Temps (geezel)
With Headers you're temp will increase.... :thumbs:
Feb 10, 2004 | 10:12 AM
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Re: Coated Headers & Underhood Temps (vinnies87)
I have heard the coating is extreamly helpful in the cooling process tho. I'm not sure. :lol:
Feb 10, 2004 | 10:14 AM
With coated headers, you underhood temps will decrease.
Feb 10, 2004 | 10:49 AM
St. Jude Donor '03
Re: Coated Headers & Underhood Temps (STL94LT1)
Yeah thats what I was thinkin..... :crazy:
Feb 10, 2004 | 12:06 PM
Re: Coated Headers & Underhood Temps (VictorRussell'92)
You will decrease the increase of your increase.
Basically.
:jester
Feb 10, 2004 | 12:10 PM
St. Jude Donor '03
Re: Coated Headers & Underhood Temps (HammerDown)
Basically.
:jester
:lol:
Feb 10, 2004 | 08:52 PM
Basically.
:jester
So temp will go up, just not as much as uncoated. :confused: :confused: :confused:
[Modified by 90 Convertible, 7:53 PM 2/10/2004]
Feb 10, 2004 | 09:05 PM
Re: Coated Headers & Underhood Temps (90 Convertible)
Generally,
Highest Temps- Uncoated Headers-- greatest surface area to dissipate high heat.
Less- Coated Headers-- depending on the coating (ceramic, not just HiTemp Paint) and whether outside only or inside and outside.
The same (if inside/outside ceramic coated) or less (if single coated or just painted)-- Stock manifolds
Lowest Temps- Thermal wrapped and ceramic coated headers. But doesn't look nearly as sharp as the coated headers alone.
Feb 11, 2004 | 01:42 AM
Re: Coated Headers & Underhood Temps (tkrussell)
yeah, coated headers will be cooler than non-coated :yesnod:
BUT i believe that coated headers are still going to be hotter than stock manifolds (because of the amount of surface area. Stock manifolds retain the heat a lot longer though since they are made of iron instead of thin pipes.
Feb 11, 2004 | 05:24 AM
Re: Coated Headers & Underhood Temps (GlockLT4)
L98 Factory Exhaust Manifolds are basically shorty headers, that's why they have the heatshields there.
c6 ,
ca ,
ceramic ,
coated ,
coating ,
decreasing ,
headers ,
increase ,
issues ,
lg ,
modesto ,
reduce ,
streets ,
temp ,
temps ,
underhood
