Shudder Effect at Highway speeds
Old Feb 10, 2004 | 03:19 PM
Frank43's Avatar
Frank43
Default Shudder Effect at Highway speeds
Just picked up a 90 zr1, and need help with an issue. The car drive beautifully until I am at highway speeds. At that point (60-80 Mph) I start to get a shudder effect through my steering wheel. Also the LTPWS light comes on.
But, all the pressure in the tires are correct. The alignment seems fine?
Any thoughts /suggestions? :confused:
Old Feb 10, 2004 | 03:23 PM
bogus's Avatar
bogus
Default Re: Shudder Effect at Highway speeds (Frank43)
the tires themselves... the old GS-C's are hard new, they become like pavement after a few years...
or, tire balance.
Congrats on the Z!!! :thumbs:
Old Feb 10, 2004 | 03:24 PM
Goody's Avatar
Goody
Check for worn tierod ends, ball joints, or bearing hubs.
Grab wheel at 12 and 6 o'clock position and report movement here.
Grab wheel at 3 and 9 o'clock position and report back here.
Place large lever under tire and attemp to lift vehicle off ground. Should not move.
Tires out of balance or just hard like Bogus said.
Good luck.
[Modified by Goody, 2:25 PM 2/10/2004]
Old Feb 10, 2004 | 03:48 PM
Frank43's Avatar
Frank43
Default Re: Shudder Effect at Highway speeds (Goody)
Do you think the Low Tire pressure sensors themselves can have anything to do with it?
..although, it has 27k on the car with Gs-cs? Hmmm... :eek:
Old Feb 10, 2004 | 05:02 PM
sraft's Avatar
sraft
I had a bad shock wich was causing this type of condition. The shuddering was so bad that I thought that the tires had flat-spotted.
Old Feb 10, 2004 | 07:12 PM
hip_about_time's Avatar
hip_about_time
Default Re: Shudder Effect at Highway speeds (sraft)
sounds like front wheel bearings to me.
Old Feb 10, 2004 | 07:16 PM
HapAFcop's Avatar
HapAFcop
Default Re: Shudder Effect at Highway speeds (hip_about_time)
Could be many suspension related things. First thing I'd check would be the tires. An out of balance tire could cause the symptoms you describe.
I don't have the low tire pressure sensors, so I don't know, but could an out of balance condition cause one to activate? I would check to see if you have any missing weights. They're usually mounted to the inside of our wheels, so you have to get underneath to check. Good luck.
[Modified by HapAFcop, 6:22 PM 2/10/2004]
To Shudder Effect at Highway speeds
