scoggin dickey vortec tpi base
Old Feb 10, 2004 | 07:19 PM
neverendingproject's Avatar
neverendingproject
Default scoggin dickey vortec tpi base
anybody out there know what the vortec - tpi base flows. i really need to know this and what AS&M runners flow so i can make a decision on heads.
if these parts only flow 250cfm i dont need heads that flow 275cfm , right?
if you don't know about the above, how about any of the big mouth bases out there? that should get me close. thanks.
Old Feb 10, 2004 | 08:38 PM
neverendingproject
Default Re: scoggin dickey vortec tpi base (neverendingproject)
anyone?
Old Feb 11, 2004 | 09:59 AM
neverendingproject
:rolleyes: ttt
Old Feb 11, 2004 | 11:40 AM
brock71's Avatar
brock71
I don't know the flow numbers, but I believe the whole reason for that base is to use out of the box vortecs. The vortecs really don't need to be ported...just a little smoothing here and there. So I guess it depends on what kind of numbers you're looking for?
Old Feb 11, 2004 | 11:52 AM
neverendingproject
Default Re: scoggin dickey vortec tpi base (brock71)
thanks for the reply. long story, i originally bought the base to use the vortec heads. seeing that the car is also undergoing a turbo install, i decided against the iron heads( that i already have). im going with afr's, but not sure which ones yet. if the intake wont flow but 250cfm, i dont need comp ported 195's. i can use street 180's which are $800 less.
Old Feb 11, 2004 | 03:17 PM
Curveit's Avatar
Curveit
Unless AFR makes a vortec head, your vortec intake will not bolt up. :chevy
Old Feb 11, 2004 | 03:47 PM
brock71's Avatar
brock71
Default Re: scoggin dickey vortec tpi base (Curveit)
What he said. If it doesn't work I could be interested in taking that off your hands for ya :D
[Modified by brock71, 8:47 PM 2/11/2004]
Old Feb 11, 2004 | 04:54 PM
neverendingproject
your kidding me? really??? :rolleyes:
Old Feb 11, 2004 | 07:00 PM
redfast's Avatar
redfast
The vortec intake is made so you can use the later style vortec heads. The vortec head desing is compleatly different than non vortec heads.
Old Feb 11, 2004 | 07:45 PM
neverendingproject
Default Re: scoggin dickey vortec tpi base (redfast)
i know, i was being sarcastic. the vortec heads are close cousins to lt1 heads, minus the reverse cooling.
so everyone knows, yes afr sells vortec style heads.
To scoggin dickey vortec tpi base
