I recently had some work done to it by the dealer. Now when I approach my car, only the drivers side unlocks. I heard someone on here mention options that you can do whil the key is in the ignition.......
Anyone have some info on the options and how I do it? Thanks! Otherwise I'll go back to the dealer. :cheers:
Re: Passive entry question (jodyeastman)
My previous Vette had a sticker on the bottom side of the center console lid... It gave instructions on changing the unlocking between driver and passenger or just driver...
Check there, if not do you have the owners manual??? It might be in there also...
After turning the system "on" as OneRedLT4 stated, you can select which dorr/doors open by putting the key in the ignition, donot turn "on". Hold the door button down until the locks cycle to your preference.
