You got a leak somewhere, check the master, line, connecting points and the slave. You might want to pull the drivers side panel under the steering wheel and see if you have clutch fluid leaking out the back of the master cyliner. You'll need a 7mm socket to remove the mounting screws.
Do you have a way to get under the Vette? Some ramps or something? You have to look under there to see if the slave is leaking. It will be obvious if it is.
I dont have any ramps but I can get up under the front when it's jacked up. Last time I replaced the master it was leaking into the inside of the driver's side so I guess I'll have to look there again. Can you tell me where about the slave cylinder is located so that I can check to see if it's leaking?
Do you know what a bell housing looks like? If so, it is on the driver's side of the bell housing. It looks like a cylinder shaped black unit bolted to the bellhousing. It has a braided S/S line running into it from the master unit. The leak could be going inside the bell housing and you'll see the dripping from the bottom of the bell housing. Otherwise, look around the fitting connections and the slave unit.
Here is a picture of the bell housing with the transmission off. I'm pointing to the stud ball and the slave cylinder is mounted just to the left of my finger where the 2 nuts are. Obviously, the slave is removed.
I just replaced mine and I was told it was best to replace both the slave and master cylinder at the same time or you run into your situation. It wasn't hard to replace the slave, just difficult to get to, like everything else on the vette.
