Part Number: 109841 Grind Number: HR-296-2S-12 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1987 Up CHEVROLET 8 ROUGH IDLE, PERFORMANCE USAGE, GOOD MID-RANGE HP, MILD BRACKET RACING, AUTO TRANS W/3000+ CONVERTER, 3800-4600 CRUISE RPM, 10.0 TO 11.5 COMPRESSION RATIO ADVISED. BASIC RPM 3000-6500
Engine Size Configuration
305-350 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 359 @Valve 539 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 372 @Valve 558
Rocker Arm Ratio 1.50
Spring Requirements: Triple Dual Outer Inner
Part Number 99846
Loads Closed 115 LBS @ 1.750 or 1 3/4
Open 336 LBS @ 1.210
Recommended RPM range with matching components
Minimum RPM 3000
Maximum RPM 6500
Valve Float 6800
Don't know what you have done to your car so far so.. That cam looks way to big to be running on a car that is stock. With that cam you need to do alot of other things to your engine befor you throw that type of camshaft in.Ex- stall converter, at least port+pollish heads/intake, bigger throtle body, biggger valve springs. But you have to thingk about is that ev\en ported cylinder heads and intake wont flow enough air for that cam to reach its full potential. Stock tpi intakes powerband dropes after alittle over5k rpm, so a cam that has a powerband that goes up to 6k+ is worthless for you. Order the tpis handbook at http://www.tpis.com and find a cam in there that will work for you or they will segest one over the phone. Hope this rambling helped a bit :party:
