NEED: LT4 Bin File (Converted OBD1)
Old Feb 13, 2004 | 03:48 PM
2ND GUNMAN's Avatar
2ND GUNMAN
Default NEED: LT4 Bin File (Converted OBD1)
Looking for a stock LT4 bin file. I found a converted LT4 OBD1 file in the
archives but it won't download anymore. Anyone have one, in .bin or .lt1 format (either is OK)? TIA. Email:
mrboston3@earthlink.net
Old Feb 15, 2004 | 11:07 PM
DR76's Avatar
DR76
Default Re: NEED: LT4 Bin File (2ND GUNMAN)
You have mail!
Old Feb 15, 2004 | 11:56 PM
2ND GUNMAN's Avatar
2ND GUNMAN
Default Re: NEED: LT4 Bin File (DR'76)
Got it. Thanks.
Old Feb 16, 2004 | 09:33 PM
GlockLT4's Avatar
GlockLT4
I have it too... man, i wish it was that easy when i needed it . I had to do it myself. You probably got the one i made, haha. I should have added a watermark to it to keep track
Old Feb 19, 2004 | 01:07 PM
bspvette86's Avatar
bspvette86
I could use a copy of these too. I've done most of the conversion manually myself, but would like some more Bins for comparison.
Cheers!
Karl
Old Mar 20, 2004 | 01:25 AM
lcvette's Avatar
lcvette
hey guys..have any of you done the OBD2 to OBD1 conversion? I am in the process of figuring it out and could really use soem help.. what i have is a 96 LT4.. and the ECM in it..also have a 95 M6 PCM here for the conversion to OBD1.. i read about impala swaps and they say knocks sensor pinout change which i understand and tach signal which is fuzzy..are both these things what needs to be changed on the Y-body? also what else if anything needs to be done and what to expect afterwards.. can it be scanned tuned normally? thanks in advance!
Chris
Old Mar 20, 2004 | 01:31 AM
GlockLT4's Avatar
GlockLT4
Default Re: NEED: LT4 Bin File (lcvette)
I'm running the OBDI in mine. You have to change the resistance level of the knock sensors (i forget the amount). After that, it's just the same. You can use all your OBDI stuff just like normal. I tune my LT4 just like i did my '94 .
Old Mar 22, 2004 | 09:31 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Default Re: NEED: LT4 Bin File (GlockLT4)
DR'76, Please send me a copy of the OBD I LT-4 Bin File to:
meyre1@aol.com
Thanks,Michael
Old Mar 27, 2004 | 11:33 PM
95Purple's Avatar
95Purple
Hello Could I get a copy of this too in .lt1??
Old Mar 28, 2004 | 07:18 PM
DR76's Avatar
DR76
Default Re: NEED: LT4 Bin File (95Purple)
I'll forward you a copy in .bin format....I used to have a conversion program, but can't find it!
I think it's at 3rdGen.org thirdgen.org. There's also some files here: http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
I'll post back when I find that conversion file...
Dr.
Old Apr 7, 2004 | 12:47 AM
GlockLT4's Avatar
GlockLT4
Did you guys all get the obdi version of the LT4 program? If not, let me know and I'll get it to you.
Old Apr 7, 2004 | 08:44 AM
MSR's Avatar
MSR
i found tables that are relevant to fueling which are not available in lt1_edit, so you can't really do a 100% conversion. the difference was large enough that swapping ecms from obd-2 to obd-1 with everything converted that was available to me ended up with different fuel trims, sometimes as much as 10%.
-michael
Old May 3, 2004 | 11:06 AM
GlockLT4's Avatar
GlockLT4
Default Re: NEED: LT4 Bin File (MSR)
That's interesting.. my fuel trims seem to be pretty good.
Old May 3, 2004 | 10:06 PM
rsafier's Avatar
rsafier
If someone could forward me a copy of a LT4 Bin file that would be great. I would like to compare my current BIN to it.
Old May 3, 2004 | 10:14 PM
GlockLT4's Avatar
GlockLT4
Default Re: NEED: LT4 Bin File (rsafier)
you've got mail!
Old May 5, 2004 | 09:35 PM
carriljc's Avatar
carriljc
Default Think that LT4 OBD1 Bin will work in a RamJet 350?
That I'm controlling with 1227730? Sounds like the specs could be close.
Old May 8, 2004 | 10:23 PM
NC-LT4's Avatar
NC-LT4
Default OBD-I question from a newby
I am considering converting my '96 to a OBD-I. Can I use any LT1 OBD-I PCM? (Buick, Caddy, Impala, Caprice, F-Body or y-Body).
Thanks for the info.
To NEED: LT4 Bin File (Converted OBD1)
Old May 8, 2004 | 10:27 PM
GlockLT4's Avatar
GlockLT4
Default Re: OBD-I question from a newby (NC-LT4)
needs to be Vette or F-body. And don't use an f-body based program or your Auto A/C won't work. I forget the model numbers on the computers but can go look if you need it.
Old May 8, 2004 | 11:52 PM
DR76's Avatar
DR76
Default Re: OBD-I question from a newby (GlockLT4)
The F-body (and I believe Caprice) PCM is 16188051, the Y-body is 16181333.
*GlockLT4:
What's this about the A/C and the F-body PCM? I'm using the F-body PCM for a '95 LT1 installed in a '76 Vette (C3) and am about to button up the A/C...should I be concerned about anything? It's mighty hot here in FL!
Old May 9, 2004 | 09:59 AM
NC-LT4's Avatar
NC-LT4
Thanks for the info gents. In addition to the auto ac, I was wondering about the other guages working with the OBD-1 PCM, like the fuel monitoring system in the '96.
What base program is recommended?
I apoligize if this discussion has been already been beat to death in the past. If it has please steer me to the appropriate source.
Thanks again..........Jim
