Pull Motor with transmission question
Old Feb 14, 2004 | 02:07 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Pull Motor with transmission question
I'm about ready to pull the motor and transmission at the same time.
How high to I need to raise the rear end for the transmission to clear?
The hood will be off and the windshield wiper motor will be off.
Old Feb 14, 2004 | 07:48 PM
JAKE's Avatar
JAKE
Default Re: Pull Motor with transmission question (Coupe89)
I've never pulled them together so I can't help. sorry.
Jake
Old Feb 14, 2004 | 08:33 PM
korvette4u's Avatar
korvette4u
totally possible... :hurray:
Old Feb 14, 2004 | 09:02 PM
Coupe89's Avatar
Coupe89
Default Re: Pull Motor with transmission question (korvette4u)
What is involved ???
I'm I on the right track ???
Old Feb 15, 2004 | 02:09 AM
thetoy's Avatar
thetoy
Why are you pulling both?
Old Feb 15, 2004 | 02:52 AM
Coupe89's Avatar
Coupe89
Default Re: Pull Motor with transmission question (thetoy)
I have a new motor 420 in the works (It will be here this week)
I dont know what the orginal owners did to the motor? Ive been told that the motor has been rebuilt, but I have noticed valve float about 3500 RPM and leeking a small amount of oil.
Then my roomate (98 WS6) and other friend (98 C5) keeps picking on me.
My Superram been sitting the the garage for about 2 years. My buddys have been calling it a big paper weight.
My transmission has 160K on it. Im having problem with the overdrive, leeking oil and Im sure it will go out after the motor gos in to place
All in all I want to make sure everything is up to par when I take out or goto the track.
Old Feb 15, 2004 | 04:19 AM
JAKE's Avatar
JAKE
24" should do it; but you should raise the entire car, not just the rear. If your jackstands won't go that high, put some 2"x4"s or 2"x6"s between them and the car.
Jake
To Pull Motor with transmission question
