Torque converter to flywheel bolt torque spec question ?
Old Feb 14, 2004 | 05:45 PM
jimmyd's Avatar
jimmyd
Default Torque converter to flywheel bolt torque spec question ?
The factory service manual says torque bolts to 45lbs. ft. on flywheel and converter cover bolts to 89lbs. ft. Is that right ? it seems backwards, Does any one know.
Old Feb 14, 2004 | 06:21 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Torque converter to flywheel bolt torque spec question ? (jimmyd)
I torque them both "very tight". And use (fresh) red lock tight...........
Old Feb 14, 2004 | 06:32 PM
Pete K's Avatar
Pete K
Default Re: Torque converter to flywheel bolt torque spec question ? (edsalinas)
:iagree:
Old Feb 14, 2004 | 06:46 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
They BOTH need to be done to the right specs. That sounds right to me.
The converter only has three bolts and there is some VERY serious power going through them. I would NOT just snug them up. I would use loctite.
There are also more bolts on the flexplate, then the converter. Hence the reason why the specs probably seem backwards. Not to mention the size difference.
:thumbs:
Old Feb 14, 2004 | 09:08 PM
jimmyd's Avatar
jimmyd
Default Re: Torque converter to flywheel bolt torque spec question ? (ski_dwn_it)
Thanks Guys.
To Torque converter to flywheel bolt torque spec question ?
