Re: Help! Code 33/34, used to be full time, now intermittent! (jackdaroofer)
Intermittent codes for the maf are usually caused by relays when they're about to head on to the mystical place car parts go when they die. If you've replaced the relays, it could be wiring. Check the connectors dealing with the maf, especially the ones to the relays. It could have been them all the time and plugging a new relay into the connector helped make a better connection. Check for corrosion and grime.
