Someone wanted to know!!!!!! HELP!!########
Old Feb 14, 2004 | 07:15 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Someone wanted to know!!!!!! HELP!!########
Someone on here wanted to know what a auto vette RPM's were and what gears they ran at 75 MPH.... Well here is some pic's if you please to help out..... I took soemat 80 mph and 70 At 80 I am running about 3000rpm,,, and this is with the stock 3.07 gears,,, does everyone agree with this.......
If you look at my pics the first 2 are ones i just took
Old Feb 14, 2004 | 08:55 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Someone wanted to know!!!!!! HELP!!######## (1990CORVETTE)
The one that wanted to know posted here: http://forums.corvetteforum.com/zerothread?id=752489
In your answer to that initial post, you neglected to reveal your gear ratio. Your 3000 rpms at 80 mph is in 3rd? If that is supposed to be O.D., there is something wrong with your speedo or you have different gears than you think.
RACE ON!!!
Old Feb 14, 2004 | 09:08 PM
Unriced's Avatar
Unriced
My 85 doesnt hit 3g's until 85ish mph.... and it's stock..
Old Feb 14, 2004 | 09:43 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Someone wanted to know!!!!!! HELP!!######## (Unriced)
My '84 with the stock sized P255/50/R16 BFG Drag Radials, turns 2500 rpms in O.D. at 85 mph. I have the factory 3.07:1 gears.
RACE ON!!!
Old Feb 14, 2004 | 11:52 PM
1990CORVETTE
Default Re: Someone wanted to know!!!!!! HELP!!######## (CFI-EFI)
RACE ON!!!
That is in O.D., you may be right then, I may have a speeed problem or a tach problem :confused: .... They are the stock gear ratio of 3.07, I know that because I have had the car jacked up on both side and have done the tire turn test.
Please advise???????? What the F$$$ :flag
Old Feb 15, 2004 | 12:34 AM
86Moon's Avatar
86Moon
I think I'm right around 2600 at 70 with a 3.33 in OD. I'll double check in the AM on the way to work. :cheers:
Old Feb 15, 2004 | 11:32 AM
Raistlin's Avatar
Raistlin
I have found it to be the case that '90 tachs are the most inaccurate of all years. Mine reads way high, up to 2000+rpm off. At watkins glen it was useless, staying pegged most of the time.
I've checked it against the computer using DataMaster data logging software to get the 2000rpm discrepency. Some say it's teh tach filter that goes bad, but i've read the filter is not available.
http://www.f-body.org/gears has an rpm/mph calculator that might be helpfull
Old Feb 16, 2004 | 06:02 PM
86Moon's Avatar
86Moon
Default Re: Someone wanted to know!!!!!! HELP!!######## (86Moon)
2200@70 on stock 16" wheels. That's at 70.
To Someone wanted to know!!!!!! HELP!!########
