Almost backfiring
Old Feb 14, 2004 | 07:52 PM
C490Vette's Avatar
C490Vette
Default Almost backfiring
When I rev the engine in Park I can hear a popping sound coming from the exhaust, almost as if the car is trying to backfire. I just replaced the rear Y pipe and mufflers today because there were 2 rust holes on the old Y pipe. Is there now a problem with the catalytic converter or something else. Any ideas why I am getting that backfire noise? Thanx.
Old Feb 14, 2004 | 08:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Almost backfiring (C490Vette)
Check base timing and TPS value at idle.
Old Feb 14, 2004 | 08:31 PM
C490Vette's Avatar
C490Vette
Default Re: Almost backfiring (65Z01)
I'm not to car savvy yet so I dont exactly know how to check the TPS. Is that something I can do on my own or would I need a shop to do it? If it wouldnt be to difficult on my own could you direct me to a site or post that describes how to do it? Thanx.
Old Feb 14, 2004 | 08:42 PM
Unriced's Avatar
Unriced
It should be in the tech tip section...
You'll have to know your way around a voltmeter to set it right.
One question though, did it do this before the work was done?
Old Feb 14, 2004 | 09:06 PM
C490Vette's Avatar
C490Vette
Default Re: Almost backfiring (Unriced)
not as bad or as often, but yes, it was making to almost backfire popping sounds
Old Feb 14, 2004 | 09:52 PM
Unriced's Avatar
Unriced
At the least, you should have a general idea of what you have to do here.
It's one of the easier things to do on a Vette but if you are not sure, you
might have to take it to a shop. Problem with that is, it may be set ok as
well as your base timing. Does it do it hot and cold? And how bad is it?
There's no one in your area that can help you with that? Seeing it's a
90, more than likely wear and tear is culprit here.. Sticky valves?
Maybe they need adjusting? Could be...Mine does it cold if you
rev it over 3g.... I am not worried about it because it doesnt do it
hot and its a high milage motor.. I dont expect it to be perfect...
Old Feb 15, 2004 | 03:19 AM
C490Vette's Avatar
C490Vette
I don't belive it does it when it is hot. I havent really checked it yet though. It really isnt that bad, it only seems to be when the car is not moving and the engine is reved and not while I am driving, and it only does it while the engine is coming down from high rpms. I really dont hear it if I push the rpms up to 3000 and hold it there. The vavle covers were recently removed to replace the gaskets and I was told the valves were in good condition. I am gonna be taking a good 2 hour cruise tomorrow, so I will check it again tomorrow. Thanx for any help.
Old Feb 15, 2004 | 03:40 AM
92corvette's Avatar
92corvette
and it only does it while the engine is coming down from high rpms. I really dont hear it if I push the rpms up to 3000 and hold it there. .
I would say there is absolutely nothing wrong. THis is not a "backfire". Don't worry about. Most of our cars do the same.
Old Feb 16, 2004 | 07:37 PM
C490Vette's Avatar
C490Vette
I am getting an error code 45, Rich Exhaust. Any connection?
To Almost backfiring
