Removing water pump
Old Feb 14, 2004 | 10:11 PM
JohnOH327's Avatar
JohnOH327
Default Removing water pump
I have an oil leak in front of my 95 LT1 engine. Trying to pull water pump to check seal in timing chain cover. Have water pump loose but can't remove. Do I need to remove the big bracket the AC and Alt. mounts to? And how do you remove it? Hayes manual useless.
Old Feb 14, 2004 | 10:47 PM
STL94LT1's Avatar
STL94LT1
Default Re: Removing water pump (JohnOH327)
If you removed all 6 bolts on the waterpump, it should just pull out. No need to remove the accessary bracket.
Old Feb 14, 2004 | 11:20 PM
96GS#007's Avatar
96GS#007
Default Re: Removing water pump (STL94LT1)
:iagree:
Old Feb 15, 2004 | 10:36 AM
GS919's Avatar
GS919
Default Re: Removing water pump (96GS#007)
Yep, there are 6 bolts, a couple of them are hidden. :cheers:
To Removing water pump
