Help with Dyno results
Old Feb 15, 2004 | 10:52 AM
dwestsr's Avatar
dwestsr
Default Help with Dyno results
I ran my 86 auto on the dyno yesterday and I'm not sure how to interpret the results. Max HP was 207.8 and Max torque was 303.9. The Air fuel ratio dropped from mid 14s down to low 12s at ~ 3500 rpm. First question is what should the car be putting out for a stocker with original cats? Second, Shouldn't the A/F ratio be 14.7 for the whole power band?
The car runs good as a daily driver and doesn't burn oil @103,000 miles. If the results I got are near normal, I'm OK but if something is wrong , I want to fix it.
BTW, I had the injectors serviced and the Fuel pressure is 38 to 40 psig.
Thanks for your input!!! :cheers:
Old Feb 15, 2004 | 12:05 PM
STL94LT1's Avatar
STL94LT1
Default Re: Help with Dyno results (dwestsr)
No, you want your WOT A/F ratio to be around 12.5:1. Looks like yours is close to perfect.
Old Feb 15, 2004 | 12:35 PM
TA's Avatar
TA
I would say those number are pretty much in line with what a stock engine would put out.
Old Feb 15, 2004 | 01:09 PM
C4-Wolf's Avatar
C4-Wolf
Mine only pulled a 235rwhp/365rwtq the first time I ran it on a dyno, and I had a whole load of bolt-ons at that point, so I think your numbers are pretty good. Especially considering it's an auto.
Old Feb 15, 2004 | 04:31 PM
dwestsr's Avatar
dwestsr
Default Re: Help with Dyno results (C4-Wolf)
Thanks for the input. I just wanted to see if it was running up to what it is supposed to do. :cheers: :cheers:
Old Feb 15, 2004 | 05:45 PM
Dan Parker '96's Avatar
Dan Parker '96
Many people focus on the peak values, but your dyno print should give you "averages" for HP and torque.
This is the number you should focus on.
Maximize your averages.
Old Feb 16, 2004 | 11:00 AM
dwestsr's Avatar
dwestsr
Default Re: Help with Dyno results (Dan Parker '96)
Dan, as info, the numbers I gave on the original thread were average HP and Torque. Thanks
To Help with Dyno results
