Spark Knock on an 87
Old Feb 15, 2004 | 03:01 PM
bogus's Avatar
bogus
Default Spark Knock on an 87
I am here in SoCal visiting bastet44, and her 87 is knocking like crazy!!!!
It's quite annoying, and, I am sure not good for the engine.
I have determined how to set the timing, removing the tan/black wire off the distributor and checking accordingly, but, what else could cause this?
Thanks!!!
:cheers:
Old Feb 15, 2004 | 03:34 PM
scorp508's Avatar
scorp508
Default Re: Spark Knock on an 87 (bogus)
Bad gas, bad plugs, etc. What did you set the timing to? 6* BTDC would be stock, go down if it keeps knocking.
Old Feb 15, 2004 | 03:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Spark Knock on an 87 (scorp508)
:iagree:
And if she's running regular gasoline try some octane booster and premium grade fuel.
BTW, what is coolant temp running?
Old Feb 15, 2004 | 03:51 PM
c4cruiser's Avatar
c4cruiser
When I wnt to Monterey in August of 2002, the highest octane gas I could find was 91 for my 92 LT1. It seemed to run OK, but didn't hear any knock even in the hills.
Sounds like bad/cheap gas. You could try some octane booster but long-term use may trash the cats if they are on the car. Dropping timing back a couple of degrees should help but you might feel a slight loss of power.
Old Feb 15, 2004 | 05:13 PM
bogus's Avatar
bogus
I am thinking that the mechanic who did the last tune up set the base timing without removing the bypass wire.
I need to get a pin popper so I can remove said bypass wire... then I can check the base timing.
All gas in Cali is 91. That should be enough for a stock L98... Also, she uses good gas. This problem has been around for a while.
Wake was nice enough to loan me his timing light... mine is 2000 miles away... :thumbs: to Wake!!!!!
Old Feb 15, 2004 | 05:22 PM
scorp508's Avatar
scorp508
No you don't. Its got a clip on the connector. Just lift the clip and pull the connector apart. Its by the brake booster sometimes hidden in the wiring harness.
Old Feb 15, 2004 | 08:56 PM
bogus's Avatar
bogus
hm... I looked for that, and could not find anything. I will check the area near the brake booster... see what I find.
Thanks.
Old Feb 15, 2004 | 09:05 PM
Pete K's Avatar
Pete K
You will be looking for a single wire with connector that is tan with ia single black stripe
Old Feb 16, 2004 | 05:39 PM
bogus's Avatar
bogus
Default Re: Spark Knock on an 87 (Pete K)
yea... found the wire... what a PITA... the wire was stuffed between the left head and the firewall. Add in a super short lead, it was nothing short of a bitch to remove.
But, I got it. I think base is now at 6*. It looked like it was 10*!!!!
As I understand it, if the computer is working ok, the adjusted timing would be 14*.....
Thanks, guys!!!! :cheers:
Old Feb 16, 2004 | 09:19 PM
bogus's Avatar
bogus
oh, my. What an improvement!
No more spark knock! It starts RIGHT up, without that overly advanced hesitation.
The tranny is shifting better and all spark knock under load in OD is GONE!
Acceloration is much smoother and feels quicker.
I reiterate what I said earlier, I suspect the timing was at 10*, if I was reading it correctly. The indicator is a bit hard to see.
Which leads me to think the timing was set without the bypass removed, or, due to the cars questionable history, major work was done, and it was never set right then.
All in all - Fabulous! Massive improvement!
Old Feb 17, 2004 | 07:05 PM
Bastet44's Avatar
Bastet44
Thanks for all your help guys! She runs so much more smoothly now!!
:cheers:
Old Feb 18, 2004 | 09:47 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Spark Knock on an 87 (Bastet44)
:cool:
Old Feb 18, 2004 | 03:45 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Glad to hear the enigine is running good again. :cheers:
bogus, I know you found the EST wire but for others to use for future reference I took a picture of it. It's a big one so I'll leave the link instead of posting the photo.
http://temp.corvetteforum.net/c4/joh...cs/estwire.jpg
To Spark Knock on an 87
