Grinding valve covers for superram?
Old Feb 16, 2004 | 01:28 PM
vetteguy216's Avatar
vetteguy216
Default Grinding valve covers for superram?
I am in the middle of the install and remember somone saying you have to grind off s part of the valve covers. Why do you have to do this and what do you have to do.
Old Feb 16, 2004 | 02:17 PM
86Moon's Avatar
86Moon
Default Re: Grinding valve covers for superram? (vetteguy216)
I don't have time right now, but I'll find the thread a little later and post it. I just did this recently. What RR's and valve covers are you using? and what year?
Old Feb 16, 2004 | 02:19 PM
CFI-EFI's Avatar
CFI-EFI
If you can't see the "What" then there is no "Why".
RACE ON!!!
Old Feb 16, 2004 | 02:22 PM
scorp508's Avatar
scorp508
Default Re: Grinding valve covers for superram? (CFI-EFI)
When installing a superram you have to take a few thousandths off the upper edge (the part the valve cover gasket goes under)of the valve covers or they'll hit the runners when you install them. This is a completely seperate issue to the normal valve cover & roller rocker issue.
I just ran mine over the bend grinder once quick and that was enough.
Old Feb 16, 2004 | 05:07 PM
86Moon's Avatar
86Moon
A little more http://forums.corvetteforum.com/zerothread?id=686050
Some links to photo's of how mine looked completed.
http://forus.com/moonunit/corvette/V...erGrind039.JPG
http://forus.com/moonunit/corvette/V...rind-2-040.JPG
http://forus.com/moonunit/corvette/V...Gaskets052.JPG
Sorry the pics aren't better. Look toward the left side of the lips on the covers.
I did the grinding with a Dremmel. Four grooves on each cover. I just placed the cover as close to where I could guess that it belonged and marked a line in the center where the cover needed to slip past the runner and ground there the deepest and less to each side, pretty much guessing. It was trial and error all the way.
Old Feb 16, 2004 | 05:42 PM
chucks88's Avatar
chucks88
Default Re: Grinding valve covers for superram? (86Moon)
I had to grind mine quite a bit. I had to do the same when I put on my after market Moroso covers on also
[Modified by chucks88, 5:42 PM 2/16/2004]
Old Feb 16, 2004 | 11:22 PM
Corvette0096's Avatar
Corvette0096
I never had to grind on mine.. This have something to do with the angle of the heads?
Old Feb 17, 2004 | 07:32 AM
chucks88's Avatar
chucks88
Default Re: Grinding valve covers for superram? (Corvette0096)
Rich, I don't know what it is. I bought this SuperRam runers/plenum-Edlebrock base from "Mitch" here on the forum. He never had to grind his valve covers on his L98 heads, however I did. :confused:
Old Feb 17, 2004 | 07:39 PM
vetteguy216
Default Re: Grinding valve covers for superram? (chucks88)
Valve covers are on guys thanks for the help.
Old Feb 17, 2004 | 08:48 PM
88_vette's Avatar
88_vette
yeah I never had to grind mine either
Old Feb 17, 2004 | 09:12 PM
86Moon's Avatar
86Moon
:thumbs: :cool: Did you take any pics?
To Grinding valve covers for superram?
