tick, tick, tick
Old Feb 16, 2004 | 05:51 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Default tick, tick, tick
Hopefully, it's not a bomb, but...
I just changed out injectors and I don't believe I heard this sound before now. I was checking for leaks and in and around the valve cover area is a distinct tick, tick, tick- very rhythmic. Any ideas as to what this may be? :confused:
Old Feb 16, 2004 | 06:13 PM
1MoorTym's Avatar
1MoorTym
Default Re: tick, tick, tick (Vett-eight-nine)
Sounds like your injectors. Some are noisier than others, if they aren't leaking your ok....
1MoorTym's Avatar
1MoorTym
Put your finger on one, does the sound follow the little pulses you feel ??
Old Feb 16, 2004 | 08:23 PM
6spd's Avatar
6spd
i did my injectors on my 91 and i have the same tick i know that wasn't there with the old injectors. so i'm guessing it's the injectors it runs mint so i don't think it's anything to worry about.
Old Feb 16, 2004 | 09:41 PM
B84RADR's Avatar
B84RADR
I had something similar happen, but I found it in the dark. One of my distributor leads was arcing across to the SR. I took care of that ;)
To tick, tick, tick
