LT1 water pump weep hole.
Old Feb 16, 2004 | 11:35 PM
C4Crazy787's Avatar
C4Crazy787
Default LT1 water pump weep hole.
Started my cam and header install today, looks like I’ll be able to reuse my water pump. The weep hole shows no signs of a leak.
I will be sealing up and venting the Opti per the Corvette Clinic Tech Tip. I don’t want to have to worry about it when the water pump does check out, then I can install a Meziere Pump.
:thumbs:
Picture of weep hole. http://www.digitalcorvettes.com/phot...7weephole1.JPG
Old Feb 17, 2004 | 12:02 AM
bogus's Avatar
bogus
Default Re: LT1 water pump weep hole. (C4Crazy787)
clean as a whistle!
You can add a drain tube that will reroute the leakage to the side somewhere...
Old Feb 17, 2004 | 10:19 AM
C4Crazy787's Avatar
C4Crazy787
Default Re: LT1 water pump weep hole. (bogus)
Great idea!! I'll do that. :thumbs:
To LT1 water pump weep hole.
