Dyno Results
I'll post results and pictures from everything I did today a little later. I'm off to go get the vette registered in Texas before they close. (got it inspected LEGALLY today :D ).
Anyway, my best pull was 312rwhp and 291rwtq. A little disappointed, considering I was expecting 330rwhp and around 340rwtq. The first run i did i only pulled 291rwhp and 280rwtq! :eek: I was shocked. Fixed the A/F and pulled the same (almost exactly). Then the next one I added some timing and it jumped up 6hp 6tq. So i found what it was wanting. I ended up adding 9 degrees of timing before it showed any signs of spark retard... (up to 45degrees at 100kpa). It was incrimental; as i kept adding timing... more hp and tq showed up.
graph pics to come in a bit.. gotta run.
edit: Ok ... here are the dyno graphs:
First run stock LT4 programming. A/F is WHACK. I think the sensor fell out or something....
Better... A/F. I actually adjusted the programming to a 24.5 constant from 26.5 for this. Did that before finding out that the sensor probably fell out last time.
Raised 90-100kPa timing by 3 degrees between 2400 & 7000.
2 more degrees of spark in same areas
Bumped timing up to 45* (3 more from previous).
Brought injector constant back to 25.5 from 24.5 (and 26.5 stock).
Tried the stock LT4 computer.. only change to it is rev limiter and fans.
Added one more degree of timing... started getting some spark retard around 3500-4000 range, so pulled 1 degree back out from there.
[Modified by GlockLT4, 7:12 PM 2/17/2004]
if you could temporarily replace the OBD-II ecm, it should tell you if there's a skew in the opti versus crank position. i think.
-michael
There's something weird going on maybe :skep:
[Modified by GlockLT4, 7:20 PM 2/17/2004]
also, mine went from 296 to 325 with the HOT, no other changes, stock programming on timing and a/f.
how long of a pushrod did you use? how many turns of lifter plunge preload?
i forget the final outcome of the header saga, what did you end up using? because the regular SBC and L98 headers and gaskets do block the tops of the LT4 exhaust ports.
-michael
-michael
[Modified by GlockLT4, 8:43 PM 2/18/2004]
-michael
Yeah, i'm positive the cam is setup right. I hit a maximum of 50 total degrees of spark. The main/extended tables i have maxing out at 45 degrees.
Is the cam timed properly? Did you degree it when it was put in? What about the pushrod length? Was it checked to assure that you are getting full lift? What is the static compression? Should be about 180psi? If its lower, too much duration, if its higher, not enough overlap.
[Modified by Dominic Sorresso, 8:36 PM 2/18/2004]
GLock,
GLock,
Haven't checked compression. pushrod is comp cams chromemoly 7.25" (stock length i think). Didn't degree it when i put it in. Was told i didn't need to worry about doing that. Haven't checked for full lift Guess i can get a caliper and measure that.
I use TFS heads and have 7.4" pushrods using a compCams HYDRLR. Take a black marker and paint the valve stem. Put rocker back on and see if the wear pattern is from upper third to lower thiird of stem. If it isn't below the halfway point, rod is too short. If it extends to the lower edge f the stem, its too long.
I would check cam timing to make sure it was put in correctly. Someone else put this in for you?
