Seat Belt locked
Old Feb 17, 2004 | 04:54 PM
C490Vette's Avatar
C490Vette
Default Seat Belt locked
The drivers side seat belt (lower half) has all of the sudden locked up, as if the cinch button is being pressed although I have checked and the cinch button is up. Is there a way to repair these seat belt systems (ie. if I find a broken something in the retraction unit is there a place to buy parts?) orelse, where can I get a new or used unit? Thanx.
Old Feb 17, 2004 | 06:31 PM
1SLO POK's Avatar
1SLO POK
Default Re: Seat Belt locked (C490Vette)
On my 85 it did the samething. GM put a recall on my seatbelts and a few other year vetts. All you have to do is go to the dealer and they will run your VN# to see if its under the recall and if so, BAM you gots some new belts!
Good luck! :cheers:
Old Feb 17, 2004 | 06:44 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Mine "locks up" also...as in when you try to pull it over to fasten it, it won't move.
Problem I found is that the sewn edge on the belt doesn't retract all the way into the bottom holder/fitting! I have to frorce it down into the housing and then it works fine.
Now, when I release the belt, I keep my fingers down by the housing and guide the belt into it
Not sure if this is similar to your problem or not
:seeya
:steering:
Old Feb 17, 2004 | 06:52 PM
1SLO POK's Avatar
1SLO POK
Default Re: Seat Belt locked (jackdaroofer)
Call GM, there was a MAJOR RECALL ON THESE BELTS!!!!!!!!!!!!!
The MAJOR problem is if you get in a wreck you may not be able to release your belt. :cry Plus you get a pair of new belts in my choices of colors. :confused: Dont even bother trying to fix them until you see if it falls under the recall. :nono: Its your call. :seeya
Old Feb 17, 2004 | 08:40 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Re: Seat Belt locked (1SLO POK)
Not only are certain seatbelts under a recall... I believe (at least I know Honda is definitely one that does) seatbelts are warrantied for life.
You may want to check, I'm honestly not positive for GM but it's worth checking into.
Mark
Old Feb 17, 2004 | 11:11 PM
TRWSD90's Avatar
TRWSD90
I would give the mechanism a "rap" there might be dirt and spilled cokes in there gumming thins up. Maybe even a spray of wd.
Old Feb 18, 2004 | 01:43 AM
C490Vette's Avatar
C490Vette
Default Re: Seat Belt locked (TRWSD90)
Looks like there might just be a recall on the seat belts after all for the 1990. The recall describes the exact problem I am having. Gonna call Chevy tomorrow. I'll let you know how it goes. Thanx everyone!
:cheers:
Old Feb 18, 2004 | 09:45 AM
Tourney3p0's Avatar
Tourney3p0
I'm exhibiting problems with the passenger side seatbelt. I'm aware of the recall but didn't think I'd still be eligible..
I just gave the local Chevy place a call and they said there are three open recalls according to my VIN - Two seatbelts and a hose under the hood that I'm not going to let them touch.
All I have to do is take the car in and they'll fix it.. I never would have thought to check if it wasn't for this thread.
Old Feb 18, 2004 | 12:32 PM
VetteBandit's Avatar
VetteBandit
Default Re: Seat Belt locked (Tourney3p0)
I know who Im calling later. :chevy thanks for the info, great forum!
Old Feb 18, 2004 | 10:09 PM
nodoubt's Avatar
nodoubt
I had that same problem on my '95. I unscrewed 3 screws on the driver's side rocker panel, then unscrewed the plastic seat belt cover in the floor...and I found a penny jammed into the mechanism. Removed the penny and then my seat belt started working again.
Your mileage may vary.
To Seat Belt locked
