Mini-ram owner's have a question
Old Feb 17, 2004 | 09:20 PM
88_vette's Avatar
88_vette
Default Mini-ram owner's have a question
If you keep the stock fuel lines and used the TPIS fuel line kit how did you hook the stock line to the new ones? Did they (TPIS) send an adapter to mate the make saganaw fuel lines to the -6an lines?
Reason I ask is I was planning on running new (AN) lines from the fuel filter up, but the accel TPI adapters I got are not right. They are two different sizes. My fuel lines are different sizes (5/16, 3/8) but the fuel rail threaded female connectors are the same size, and thread pitch. Thus the smaller one will not fit but one does (the bigger one). :banghead: :banghead: :confused:
Old Feb 17, 2004 | 11:23 PM
88_vette's Avatar
88_vette
Default Re: Mini-ram owner's have a question (88_vette)
maybe this will help will the accel part number 74721 work? I have part# 74730 and it's not right for what I want.
Old Feb 18, 2004 | 03:44 AM
LD85's Avatar
LD85
http://forums.corvetteforum.com/zerothread?id=551515
[Modified by ld85, 8:22 AM 2/18/2004]
Old Feb 18, 2004 | 08:59 AM
88_vette's Avatar
88_vette
Default Re: Mini-ram owner's have a question (ld85)
Thanks ID85 you're a life saver.
Just a note the 88-up do have the same size return line, and feed line. Both are 16MM. That's where I raninto this little problem. I've been looking everywhere for those female saginaw deals. I could only seem to find maleXmale ones.
Thanks again I'm back on track now. :hurray: :hurray:
Old Feb 18, 2004 | 09:02 AM
LD85's Avatar
LD85
Good luck, I'm just glad the archives still had the info!
To Mini-ram owner's have a question
