Horsepower Updates Need Injectors?
Old Feb 17, 2004 | 09:55 PM
90Indy's Avatar
90Indy
Default Horsepower Updates Need Injectors?
I have a stock 90 L98 and I am getting the parts together to start a HP update. This includes an Edelbrock Intake Base/Runners, 52mm Throttle Body, Cat Back Flowmaster II Mufflers/Y Pipe and a ProCharger Intercooled Supercharger. My question is this, do I need to also go to the next larger injectors? I suspect I may have a bad injector or two due to a cold start/idle problem I am currently experiencing. This is not a definite though. I want to get the most performance for my effort and I will have the injectors out anyway so replacing them will not be a problem. Thanks for your help.
Old Feb 17, 2004 | 09:57 PM
vader86's Avatar
vader86
Default Re: Horsepower Updates Need Injectors? (90Indy)
If you werent going to install the SC, I would say no, you just need them cleaned/serviced.
Since youre going with a SC, you would probably benefit from slightly larger injectors, depending on how crazy youre going to get.
