please, explain this to me.. ( about engine balance ).
Old Feb 19, 2004 | 06:56 AM
devilfish's Avatar
devilfish
Default please, explain this to me.. ( about engine balance ).
Our engines are neutral balanced at the front ( damper side ), but not at the rear ( FW/FP ) right?
Im looking at 383 stroker kits with cast crank, and they all say its external balanced ( 86 and later with 1 pc main seal ). Some companys offer to balance the kits. But thats not really going to help me is it, cause they dont have MY ZF dualmass FW. So unless I send them my FW the balance is just a waste of money, do i understand this right??
This must mean that if I whant to get a new FW som day. I must take out the internals and rebalanced it? IF I dont find a machin shop that can "transfer" the old FWs balance to my new FW? Or does the external balance fw and fp have the same offset all the time. Like i heard the 400 engines has?
Im having a hard time belive that GM balanced all the engines that came out, dident they just use the same offset on all the FW and FPs?
How do the shops use the FW to balance the rotating assambly? Do they drill holes in the FW? I know my ZF dual mass has tiny wights inserted. Are the ZF FW zero balanced without those tiny wieghts? Or are these wieghts only for "fine" adjusments?
Please help me understand this..
Old Feb 19, 2004 | 08:26 AM
bogus's Avatar
bogus
Default Re: please, explain this to me.. ( about engine balance ). (devilfish)
you about have it.
when GM balanced the motors, they did so with the dual mass flywheel. The tiny weights were used to bring the entire assembly into balance.
if it was me... I would have the motor internally balanced, then, get a single mass flywheel to zero balance. that way, you will never have to worry about the flywheel ever again!
Besides, the DM is HEAVY and EXPENSIVE. This is a great chance to get rid of both issues. All you will pick up is some tranny rattle at idle and low speed. Once over about 15mph or so, there will be no more noise than usual.
The DM weighs about 40lbs. Even if you use an F-body flywheel (93+ Camaro/Firebird) cast iron single mass, you will loose about 1/2 the weight!
You will need an Fbody friction disc to go with your existing Corvette pressure plate and throw out bearing. You might want an adjustable pivot, too.
It's the way I WILL do it when I rebuild my engine.
Old Feb 19, 2004 | 10:24 AM
devilfish's Avatar
devilfish
Default Re: please, explain this to me.. (bogus)
ok thanks.
Why is it that its only "special" cranks that can be internal balanced and not cast cranks??
Old Feb 19, 2004 | 10:59 AM
bogus's Avatar
bogus
Default Re: please, explain this to me.. (devilfish)
ok thanks.
anytime.
I donno.... good question.
Old Feb 19, 2004 | 11:13 AM
MrJay's Avatar
MrJay
It is not that the cast cranks cant be internaly balanced it is the cost that GM is looking at.
Jay
Old Feb 19, 2004 | 12:00 PM
JCAIRE2's Avatar
JCAIRE2
ok thanks.
Any crank can be internal balanced. Most factory cranks are pretty darn close to balanced anyway, so GM was looking at it from a cost/time perspective.
I will switch to internal balance when I build my 383. When you bring your rotating assembly to the machince shop, you always want to bring them your damper, flywheel or flexplate, rods and pistons.
Old Feb 19, 2004 | 12:38 PM
93Quasar's Avatar
93Quasar
There have been a lot of recent posts on this, many of which are mine.
You can neutral balance your rotating assembly (crank and internals), and then mate it up to a 0 balance flywheel as stated above. I have a cast Scat crank that is internally balanced in my 383. You will want to read this before you attempt to have a dual-mass neutral balanced:
http://forums.corvetteforum.com/zerothread?id=738670
Quite a bit of material needs to be removed from the dual-mass to get it neutral. The FW is not neutral balance with all the weight pellets removed. My theory is that they are for fine-tuning as you said.
More reading on the subject:
http://forums.corvetteforum.com/zerothread?id=750197 http://forums.corvetteforum.com/zerothread?id=749510
I've been told that GM did spin balance every engine - after it was assembled. Not something you can have done at the average machine shop.
Old Feb 19, 2004 | 01:13 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: please, explain this to me.. (Jeff Hickman)
I'm pretty sure they did and still do spin balance their engines. The difference between an external spin balance and an internal machine balance is up to 2 hrs, depending on the operator and crank material.
Old Feb 19, 2004 | 01:54 PM
devilfish's Avatar
devilfish
Default Re: please, explain this to me.. (JCAIRE2)
if it is like you said, that means that all the FW to our cars have the same out of balance offset. And then you just use the tiny wieghts to fine tune it ( put on the same place on your new FW to your old one ).
If thats NOT the case then replacement FW should be inpossible.
Old Feb 19, 2004 | 02:28 PM
93Quasar's Avatar
93Quasar
Yep, that's how it's done.
Old Feb 19, 2004 | 03:03 PM
devilfish's Avatar
devilfish
i see..
Has all the ( 86 and later ) chevy 350 fw and fp the same offset balance? Cause I can se in the summit catalog on fw that its printed external or internal balance? Mayby that mean that the internal FW has zero balance and the external has the "stock" cehvy offset?
Old Feb 20, 2004 | 04:36 AM
devilfish's Avatar
devilfish
tt
To please, explain this to me.. ( about engine balance ).
