u-joint question
just got on autozone.com, and there's some cheap bruteforce u-joints for $14. That fits nicely in my budget, cause i'm dirt poor. Are there any horror stories with these, or will they work good enough? Got a pretty much stock 85 with a crapload of miles on it.
[Modified by Corvettaholic, 8:09 PM 2/19/2004]
http://personal.tmlp.com/scorp/vette...nts/index.html
I would recommend getting under there a day or 2 earlier and hit all the bolts - exhaust and ujoints - with some PB blaster to soften them up a bit.
From what I have read, that service seems to hover between $200.00~$300.00, plus parts. I would also change the rear diff fluid. Use 2 bottles of Diff Additive - That's Gordon Killebrew's latest recommendation, he is god, so, I do pretty much what he suggests. :)
I bought the Brute Force before I heard the bad things... but the bad seems to be limited to racers and not street drivers. The issues seem to be related to hard launches... I will replace those with Spicers, next time.
I don't see you having a problem with the Brute Force. I had them installed on the drive shaft 2 years ago, no problems... but I don't race. So for street use, they should be fine.
I replaced two on one side a few months ago but now the other side needs doing.
One side took me about 2.5 hrs.
You don't need to drop too much but the u-joint bolts are a little fiddly to get at.
Good Luck
RACE ON!!!
When I have a tight taper fit like a tie rod end or ball joint to deal with, I use this proceedure. After removing the cotter key and nut, I rap on the female part, adjacent to the tapered hole, with a hammer. Then I thread the nut, castles down, back onto the stud, until the top of the nut is flush (even) with the top of the stud. With a piece of scrap metal as a "load distributor", over the nut and stud, I try to drive the stud out with a few hammer blows. Sharp raps seem to work better than huge blows. All you have to do is break the grip of the taper fit. With a pickle fork, you risk damage to the boot. I don't know if it was steel in aluminum, or what, but the first time (19 year old Corvette) I separated the tie rod end from the rear knuckle, it came apart so easily, it was scary. That is MY experience.
RACE ON!!!
If he does it how I do it he'll need a tie rod end seperator fork. If he doesn't have one then he can rent it at Autozone for $15 and get his $ back when he returns it.
